Simple Way To Create Consistent Silk Cores for Dubbing Brush
Post by letumgo » Tue Jan 15, 2013 10:02 pm
I found a simple way of creating uniform lengths of silk thread for making dubbing brushes, without wasting a ton of silk thread. Simply wrap the thread around the Clark dubbing block (end-to-end) and your index finger (spacer), as shown in the photos below. This method makes it easy to make a set of silk cores to fill a card with brushes.
Grasp the dubbing block as shown, and trap the tag end of the silk under your index finger.
Wrap the silk around the block (end to end) and over the top of your index finger. The finger serves as a spacer, to add an extra length of silk, and form a gap to easily clip off the silk at the end of the process. Keep the wraps fairly loose, to avoid cutting off the circulation in your finger tip (like I did).
Continue making wraps (one wraps for each dubbing brush you want to make). In this case I wanted to have enough to fill one of Lance's handy-dandy cards, so I made twenty wraps.
View showing the backside of the dubbing block and the twenty lengths of silk (before trimming).
Slide the tip of your scissors into the gap at the edge of the block. Hold the silk strands with your thumb (frontside) and middle finger (backside). Cut all of the silk strands. They will all be uniform length, just long enough for making dubbing brushes.
Slide the strands of silk into the dubbing card, and your ready to get making dubbing brushes.
gingerdun
Re: Simple Way To Create Consistent Silk Cores for Dubbing Brush
Post by gingerdun » Tue Jan 15, 2013 10:34 pm
That makes sense, and is fast.
Waxing the first four inches or so of the 11" length of detached thread is not as easy as when it is still attached to the bobbin, I find, but not that difficult with some practice. Worth it to save the time spent measuring each length.
Thanks for taking the great photos too. They make it so clear.
Lance
Post by letumgo » Tue Jan 15, 2013 10:41 pm
Lance - My daughter gets the credit for the photos. I had to recruit her to take the photos, since I needed both of my hands to demonstrate the method. I couldn't have done it without her help. :D
Post by Mataura mayfly » Tue Jan 15, 2013 10:44 pm
Dude! Just as well it was not an hour between shots or you might have been looking for a new finger tip! Reminds me of the rubber ring method we use to remove lamb tails and the bits you might use for a Tups dressing.
Nice wedding ring by the way, very ornate. :D
Post by letumgo » Tue Jan 15, 2013 10:53 pm
Frilly, isn't it? I love my wedding ring. :D
Post by Mataura mayfly » Tue Jan 15, 2013 11:05 pm
letumgo wrote:Frilly, isn't it? I love my wedding ring. :D
Was an honest compliment, I wear a Claddagh ring 24-7 that Kim gave me. I do think it a nice piece of jewellery. ;)
Post by chase creek » Tue Jan 15, 2013 11:34 pm
Great idea! I had marked 11 1/2" off on my desk, and was measuring the lengths one at a time. I like your method, a lot faster.
Thanks.
Post by wsbailey » Tue Jan 15, 2013 11:47 pm
Here's a link to some tips on waxing a length of silk thread: http://archive.org/stream/howtodresssal ... 4/mode/2up Bill
Post by letumgo » Tue Jan 15, 2013 11:50 pm
Rodger - I had settled on the same length, when I was measuring each one. I like this method better due to the speed/simplicity.
Bill - Thanks for the great link. I've downloaded a copy of the PDF version for further study. Very useful info.
Post by William Anderson » Wed Jan 16, 2013 12:35 pm
Dang, Ray, I thought I had a quick method (how fast does fast have to be?) with my marks on my tying station...but this, this is really something. I love the mind of an engineer. Great pics.
