Fly styles
Mike Connor
Fly styles
Post by Mike Connor » Wed Nov 23, 2011 2:35 pm
Since a few people asked.
Problems often arise with many older fly patterns, because the materials are sometimes very difficult to obtain, or people don´t really know what they need to get! The original feathers of even rare and protected birds are given in some cases, many of these birds are now endangered and protected, and no attempt should be made to obtain such feathers, even possession of such material in some places is illegal. You may be lucky and find a bird dead on the road somewhere which you can use, otherwise you should use the substitutes.
Hen hackles are not usually very good substitutes for game bird and similar feathers, although they may be used in a pinch. They are often very wispy and thin, much thinner in the barbs than other feathers, less mobile, and several turns of hackle are often advised to obtain the required effect, whereas one will usually do with the original feathers. I don´t personally agree with using more turns of hackle, but many authors have recommended this over the years.
When using hen hackles try to find coarse webby feathers, (if you buy them, these are usually the cheapest by the way!), and if you can find them, with broken colouring, like mottling or barring, these are far more useful and effective than single colour feathers. Avoid dyed colours as much as you can. This does make a difference. If you do want to use dyed feathers, then you might like to have a look at this first. If you just want half a dozen feathers of a particular colour, then use permanent markers to colour them, this is a great deal easier and cheaper than dyeing in the conventional manner.
Genetic hen feathers are not very good for most of these flies, the feather quality is far too good! Much of this hackle is almost web free and very fine and springy, which reduces the intrinsic mobility considerably, and this in turn reduces the flies effectiveness for many purposes. Coarser feathers imitate insect legs better usually. There are some new materials on the market now, notably Brahma hen feathers, ( from Whiting farms) which may be well suited to a number of spider type flies. Hans Weilenmann has a few very nice looking patterns for these on his site. I have used hen back feathers for some things, but up to now I did not really need to use many substitutes, as I have a good stock of materials, and I don´t dress many flies which use extremely rare or protected birds and animals.
Many old time dressers, (including Skues in fairly modern times, who did a great deal of research into north country patterns,) were of the opinion that feathers with a good amount of natural grease or oil in them were better for fly-dressing than any other type.
This may seem paradoxical for wet flies, but it is nevertheless a fact that many of the feathers used and recommended for these patterns do contain a lot of natural grease or oil, and are more effective for many flies. Washing the feathers gently and carefully in warm soapy water made with pure soap, to get them reasonably clean, does not detract from this property, however hot dyeing them certainly will, as most of the natural oil is boiled out, some modern detergents should also be avoided for this reason. This is probably the main reason for some dyed feathers being less effective for dressing purposes.
Many bird feathers, notably Pigeon and Dove feathers among others, would seem at first glance to be ideal for fly dressing, coming as they do in a wide range of attractive colours and sizes, even metallic glints are common, excellent for imitating some insects. Strangely enough most old time dressers gave these feathers a wide berth, maintaining that they were "dry" lifeless and dull.
There are hardly any patterns using these feathers, even though they were widely available and easy to obtain at the time, quite the reverse of some of the feathers actually used. It is highly unlikely that this was done without good reason, when one considers the trouble many went to in choosing feathers for dressing their flies. This is probably another reason why hen hackles are not as good either. The same is true of most of the furs used, water rat, shrew and several other animals were used because the fur is naturally waterproof when untreated. This bears thinking about when substituting materials. While we may not always know exactly why some materials are better than others, we may rest assured that these flies are sometimes the result of years of experimentation and research, and it would be foolish to take this lightly
Pure waxed silk was almost always used for many of these flies, the type of wax used varied quite considerably, as it was often made up mainly of resin. ( Purified pine resin was often used). For the majority of flies nowadays, ordinary beeswax suffices to wax the silk if this is required. It is possible to use modern tying thread, and just form the bodies of waxed or unwaxed floss silk or thread, this results in a somewhat thicker body, and should not be overdone, but it does work.
Small thin bodies are more effective on spiders usually. Some modern threads may also be used waxed to obtain the effects required as well. One way of obtaining very good translucence is to wind a flat body of gold or silver tinsel, and overwind this with one layer of fine waxed silk. This looks very good, the tinsel shines through when wet, imitating natural translucence very well indeed.
Try to avoid handling the flies too much with your fingers after dressing them, as this transfers natural oils from your fingers to the feathers, and makes the flies very difficult to sink. Your hands and fingers should be scrupulously clean when dressing flies anyway, especially silk bodied ones, as every speck of dirt or grease shows up plainly on the body, and makes the flies look rather tatty, it is doubtful whether the fish really mind about the tattiness, indeed, the very tatty ones tend to catch more fish! But the oil from your fingers can be a problem.
I have seen one or two flies dressed with bodies of "larva lace", which is basically fine soft plastic tubing, and similar synthetics, and the translucence and colour thus obtained is excellent, in many cases better than the original pattern with silk, to human eyes at any rate. I mostly still use silk though! I have tied up a range of patterns with larva lace, but somehow never get around to trying them out properly! The originals are hard to beat as fish catchers! Also, some experiments I did with this material left me rather unconvinced as to its effectiveness.
Judging by the number of e-mails and other correspondence I have been receiving lately on the subject, and also at the time this article was originally written, Yorkshire flies or "Soft Hackles" as they are also known, are becoming very popular once again, although for a while they seemed to have fallen into disuse, or been neglected in favour of more exotic or complicated patterns.
These were the first flies I used as a boy, and they were very successful indeed, in fact most of the people I met or knew at that time in Yorkshire fished these flies almost exclusively. Dry fly fishermen were very rare in the North in those days, although there were some.
Many of the old standby patterns such as Partridge and Orange, Snipe and Purple etc, will still be found in almost every Yorkshire flyfisher's box, and even some of the less well known patterns are still popular in many parts of England. Several first class books about north country wet flies were published, and even today still enjoy wide acclaim.
There were basically three methods of fishing these flies, the old traditional method of down and across using a fairly long soft actioned rod and a team of two or three flies, , perhaps working the flies, and also allowing them to swing across the current on a tight line, the “new” method ( although it was already an old method !) popularised largely by Stewart in his book "The practical angler", whereby the flies were mainly fished upstream dead drift, much like dry fly fishing, or more modern nymphing techniques whereby the angler moved upstream casting ahead using a long ( Stewart used a comaparatively “short” ten foot rod), stiffish rod and a short line, and the downstream method, whereby the flies are cast across and slightly up from the anglers standpoint, and fished dead drift to below him, then the angler moves down a yard or two and casts again. In some places nine or ten or even more flies were used on the leader ( still mostly referred to as a “cast” in the UK ).
The only really successful method of those described above, is the upstream dead drift method, where the angler moves carefully upstream, casting often at every likely spot, or of course at rises or marked fish. The other methods will take fish, especially in coloured water, or fast broken riffles, but not as many and usually of smaller size, whereby many fish are also lost due to just being "pricked" or "turned over."
Time and practice is required to master the really successful upstream working method, and a longish rod (rods of between ten and fourteen feet were used for this method) is a necessity, as with shorter rods it is just about impossible to gain the perfect control required. I use a number of modern match rods for this purpose, as fly rods of this length with the required action and delicacy are hard to acquire nowadays.Nine feet is about the shortest length with which this method is really practicable, and is difficult even then. Stealth and delicacy of presentation are prerequisites of this method. I have just acquired a thirteen foot telescopic rod, which I am in the process of testing. It is a little cumbersome on small streams, but does give marvelous line control.
Attempting this method with the relatively short rods now popular is more or less a waste of time, as line recovery, casting etc are just too difficult and tiring. In fast flowing streams the flies will be back at your feet before you even have time to see where they landed. The trick is to use a line not much longer than the rod and to raise the rod to maintain loose contact with the flies, casting long lines makes this just about impossible, as one is then obliged to retrieve line per hand.
The casting line should be kept short, preferably not much longer than the rod, not including the leader ( cast), and one must cast very often indeed, the drift sometimes being very short before drag sets in. Some old experts “worked” the flies, by vibrating the rod, and using other techniques. This technique is however very difficult to master, and requires considerable practice. Some people are apparently much better at this than others, as they “vibrate”better. Sounds a bit silly, but it is true.
Dragging flies may often tempt usually small fish to grab at them, but most decent trout will ignore them, as they are perfectly aware that a natural insect does not behave in this manner. This should be borne in mind when fishing upstream wet flies, or indeed any other flies! Their is a difference between “working” and “Dragging” !
Although these flies are often referred to as "Yorkshire wet flies" or "North country flies" in actual fact many of them may be traced to areas of Derbyshire, Lancashire, the Lake District and many other places in England Scotland and Wales. Their main characteristics are their small size and almost austere sparseness and delicacy of dressing. The style of fly also varies considerably from area to area, although ostensibly the same pattern.
The popular name "North country flies" is probably due to the title of the second edition of the book by T.E-Pritt, (the first edition was called "Yorkshire Flies,") this book was first published in 1885, the second edition in 1886, and is now very rare and valuable indeed as a collectors item. This book was more or less the bible of north country patterns, became an instant classic, and was also remarkable for the eleven high quality hand coloured plates in the book. I have a facsimile reprint of the second edition, but this was also limited to five hundred copies.
Nowadays in many places, one fly only on the leader is the rule, but the basic methods are still effective if one can manage them. Some methods wont work well or even at all with only one fly! These flies are quite good imitations of many insects, are relatively simple and cheap to tie, and one may catch prodigious numbers of fish with them. Larger soft hackles are now fairly common, but years ago the small delicate flies in sizes 16 to 12 were by far the most popular and effective lures. In point of fact one was generally advised to fish flies a size smaller than the natural if possible, as this was invariably more successful. Only changing to larger flies in “big “ water ( heavier flows).
The larger soft hackled flies will catch fish, but it is uncertain what some of them are supposed to represent. Probably the semblance of life and mobility engendered by the soft hackles tempts fish to grab them anyway, even though they are far larger than their natural counterparts. There is no such thing as a size 8 dark spanish needle, or a size 10 iron blue dun. Patterns tied in these sizes do catch fish, but rarely quite as well as the smaller more accurately imitative patterns.
I know and have also heard of quite a few people who fish very large soft hackles with considerable success, but mostly as general or attractor patterns, and making little or no attempt to match the hatch. This was not the case years ago in the Yorkshire Dales and other places where many of these patterns originated. Great pains were taken to match the natural flies in size and colour, and many different feathers were tried until the best imitation of the natural insect was discovered. Many of the feathers used at that time are no longer available, and some of the substitutes leave much to be desired, it is nevertheless still possible to tie a range of soft hackle patterns to suit almost any eventuality on the water.
Many North country and other spider flies were dressed with a "kick", for upstream fishing. When "worked", these flies have a particularly lively action. The hackles literally "pulse" when manipulated properly. Which is presumably the same reason the Italians dress them in this fashion. After use, such flies must be carefully dried and fluffed up, as otherwise the hackles may take a bend in the wrong direction, and this makes them much less effective.
Practically all the spider type flies were also dressed with a kick for upstream work. There is some info on this in various literature. This however usually works best with slightly stiffer hackles, which give more movement when worked. Although I have also seen partridge hackles dressed in this fashion. Many modern dressers incorporate a very small "thorax" of fur, to help force the hackles forward, and keep them there. One may of course simply use thread, as in the majority of Italian flies.
The origins may be different from the Italian flies, which are identical in form and function, although who knows? Maybe some Roman soldier, perhaps even originally from the Po valley area, brought some flies with him when he invaded Britain? This may even be the origin of a whole host of flies and techniques. The Romans were certainly active in those parts of Britain where such flies and techniques were used, and it is not unreasonable to suppose that they may even have introduced them. They had very great influence on a whole host of things. Wherever they originated, the design and function are identical.
False casting with modern rods will dry these flies very effectively indeed. However, using the long rods, no false casting is done at all, there is no call for it, and the flies do not get a chance to dry out. The reason for drying the flies after use, and before storing them again, is that otherwise the hackles may mat together, and dry into a different curve. As long as the flies are in use, this does not occur.
There are also various tricks for "bending and setting" hackles. One common method in Yorkshire, which also gives some very typical appearances to the flies thus treated, is to pull the hackles over the edge of the thumbnail after the legs and wings have been "set". "Setting" here, refers to the fact that the hackle is split more or less equally above and below the hook shank, to represent wings and legs separately, and also the angle at which the hackle is set on the hook. In some flies a few extra fibres were added as wings, and the hackle itself, was below the shank.
This is a North-country-style spider with the hackle set above and below the hook, and "bent" to shape by curving the fibres over the thumbnail. This style is a fairly good upstream fly, but will lose its shape immediately when used downstream or worked. It is purely for dead drift work. The hackles are “set” above and below the hook to represent the wings of a spent or otherwise drowned fly. This technique was very popular with some dressers in Yorkshire. Many dressers being of the opinion that it was a much better imitation of the naturals when dressed in this way. Of course, there was a lot of controversy on this too!
Generations of fly-dressers have struggled with the interpretation of “hackle turns”! Authors and others, often remonstrated that flies should be kept sparse. However, if you want very sparse flies, then simply count the number of barbs on the feather you wish to apply! If you want a fly with eight barbs, then strip off all the other fibres before you wind it! Of course there are other techniques for applying hackle, apart from simply winding feathers.
The vast majority of wet flies and spiders were dressed in the sizes 14 or 16, with quite a few in size 18 if the feathers were obtainable in this size. If in doubt, go one size smaller. Many of the older experts were of the opinion that the small flies were much more effective, but also complained constantly that feathers in these sizes were often difficult or impossible to obtain.
Variations in the dressing of these types of flies are legion. Many authors and dressers over the years have evolved various methods of hackling, dubbing etc, for various purposes. Some of these methods, or styles, as opposed to the specific patterns, have become more or less standardised in some places, often for the wrong reasons, and this is rather unfortunate. Some of these flies must be dressed in certain ways with certain materials if they are to be effective as they were originally designed to be, but this does not mean that all such flies should be dressed in this manner, quite the contrary.
Dogmatic assertions that a soft hackled fly should have a hackle one and a half times the body length for instance is fairly nonsensical. The insects one is attempting to imitate are all different, and there is no “Standard” size for wings and legs on the creatures.
One of the reasons for some North country flies having long hackles is the simple fact that these hackles are not available in smaller sizes! There are other reasons as well of course. Many of these flies have been in use for hundreds of years because they work extremely well, and although appearing very simple, are in fact pinnacles of achievement and development,which may hardly be bettered as imitations, when tied with the correct materials, and in the correct way.
"Umbrella" hackled flies, where the hackle is tied in to spread it evenly and concentrically around the hook, which are fairly popular nowadays, are often quoted as being the perfect way of hackling soft hackles. This is simply not so. This method is excellent for many wet flies, and is known to work well, but for many upstream wet flies it is far better to give the hackle ( and the wings) the correct "set" meaning to fix the hackles in such a way that the fibres are more or less evenly distributed above and below the hook in anything from almost flat to the body up to an almost vertical plane, thus more efficiently suggesting wings and legs, and making the fly more stable and a better imitation for dead drift operation, either up or downstream.
There are no natural flies whose legs and wings radiate from the body concentrically over 360°, unless you take hairy caterpillars into account!, and flies tied in such a way can not possibly be good imitations of naturals usually, unless other criteria are taken into account, such as mobility, special technique of use, semblance of life, trigger behaviour, etc. Dry flies are tied like this to help them float, not to make them better imitations. There is no sensible reason to do this on wet flies usually, unless specific actions or movements are required, as in woolly buggers and similar flies.
Quite a few authors and dressers advocate the use of herl, fur, or wool thoraces, on many upstream flies, although actually only a few of the original patterns had these additions, maintaining that they then fish better, as the hackle is held upright and away from the hook shank, and gives a greater semblance of life to the imitation, or a better profile, or because it just "looks better." Some others maintain that a small drop of varnish (head cement) on the finishing knot should be allowed to seep into the hackle roots, thus stiffening the hackle somewhat, and helping to maintain it in the desired position. Some avoid the whip finish because they say it makes the head too big, especially on flies with herl, or wool,or fur heads, some use a single half hitch with varnish, some use no varnish, and so on.
None of these ideas are carved in stone! The whole point is, before dressing a fly, you should know what you want to imitate with it and under what conditions, and these considerations should be reflected in the dressing. Upstream wet fly fishing with the correct imitations and techniques is by no means "chuck and chance it" as is often implied, quite the contrary. When practised correctly it is a deadly and precise method of catching large numbers of fish in a very satisfying and pleasurable way.
Vehement assertions that hackles "must" be tied in by the tip, or one side of the hackle "must" be stripped, are also rather ridiculous. These flies are deceptively simple, deceptively because the possible variations in dressing styles and designs, and combinations of them are more or less infinite, and all were originally invented for specific purposes.
Some hackles have to be tied in by the tip because it is more or less impossible to tie them in by the stalk, and still achieve the required effect, this is dictated by the material in this case, other hackles may be better tied in by the stalk or other variations used, depending on the material used and the effect or property which one is seeking to obtain. Many feathers have well defined tapers, meaning the fibres at the tip are usually shorter than the fibres at the butt, it is usually more natural looking to tie such feathers in by the tip and wind in such a way that the shorter fibres are at the rear of the hackle towards the hook bend, but you do not have to do this, if you want to try it the other way go ahead!
Natural insects which fall into the water, or live in it all the time, all behave and appear differently, depending on the insects themselves, their size, colouration, degree of robustness, delicacy, swimming ability or the lack of it, etc. These flies were designed and tied to imitate a multitude of such creatures in all manner of forms and circumstances.
Really good wet flies have to be good imitations, because the fish see them directly and closely. There is no one "perfect" soft hackle form or set of dimensions for all situations, and it is arrant nonsense to even suggest such a thing. Many patterns may be used "universally" as they imitate so many creatures, that they will be taken for something or other at practically any time on any water. In fact many people only use two or three flies in total. Stewart of "The Practical Angler" fame, only used three general spider type patterns usually and had three winged patterns in reserve, should his spiders fail him, or be required for certain types of water, which apparently hardly ever occurred, according to his writings.
Some styles of dressing are shown below, with comments on the situations and conditions for which they were originally designed. A point I have made before on various occasions, but which is still worthy of repetition here, is the fact that years ago "style" meant the variations in fly patterns making them suitable for different conditions, and the way in which they were dressed in order to achieve this.
"Style" has now come to mean the little idiosyncrasies which many dressers build into their flies to make them stand out from others. This is not the same thing at all. The first reason is an eminently sensible and practical consideration for making the flies more accurate imitations, and thus more attractive to the fish, which is the object of the whole exercise, and the second is to make the flies more attractive to people and boost ones own ego with a "personal stamp" on ones work, which, while it may be profitable or fun or interesting, has nothing whatever to do with the behaviour or appearance of insects, or the predilections of trout.
People often ask me why I do not use the "traditional" down-eyed hooks for my north-country-style wet flies. In fact I have been told on occasion by one or two experts that my flies "don't look right " or are "tied on the wrong hooks," or "you will never win a prize with flies like that" and similar encouraging remarks. Well the reasons are as follows. For hundreds of years these flies were tied on hooks without any eyes at all, directly to horsehair or gut, eyed hooks being a relatively recent invention, so there is no “tradition” of up or down eyed hooks as such. I prefer straight eyed hooks for several positive and specific reasons as well, the head of the fly may be finished very small and very close to the eye, much closer than with up or down eyed hooks, and this allows very fine small finishing knots important on flies with herl or fur heads. Silk thread is also thicker than many synthetic threads used today, and one has larger heads anyway on silk thread flies as a result of this.
The appearance of bulk engendered by up or down eyed hooks is avoided, the tendency of the offset hook eye to pull the fly out of line on the cast (leader) is obviated, and the flies thus fish more naturally. This reduces hinging and breaks at the knot as well. The appearance of the finished fly more closely resembles the real thing in my opinion, when tied on these hooks, but this is purely my personal opinion. When being "worked," or in heavy water, the offset eye can cause the fly to generate too much turbulence, and can actually act as a sort of miniature diving plane, causing the fly to hang and behave in a very unnatural manner. With straight eyed hooks this simply does not occur.
Drennan Carbon Specimen hooks with straight eyes, which I mentioned in a previous article are the best hooks I have found for this purpose to date, and I have tried lots, even making some myself. I also use them for dry flies as they are fine wire and extremely good quality. They are also cheaper than most purpose made trout hooks, as they are made for coarse fishing! It is an unfortunate fact nowadays that if something is made specifically for "fly" fishing it invariably costs more than a similar product just as good or better, but originally made for some other purpose.
So, on to styles. The Greenwells Glory has been chosen as the pattern, the same materials have been used in all the flies shown in the style section below, apart from the addition of a small fur thorax on some to obtain special effects, the only other differences are in style.
Traditionally, and in many modern books, the materials for patterns are often given in the order in which they are tied in, this means that the materials list should be adjusted to reflect the style of fly being dressed! If the Wings are tied in first then they should be first in the list, if the wings are tied in last, then they should be last on the list and so on. A pattern recipe written properly should tell you something about the style and dressing operations, and not just be a list of materials. I have simply given a list of materials for all the flies here listed, as the dressing and style is discussed specifically in the text anyway. A pattern from a hand dresser may have a different material dressing order than a pattern from somebody who uses a vice. Also, the method of finishing affects the dressing order. It is as well to remember this when looking at older fly-dressings.
Greenwells Glory
The materials are:
HOOK. - This fly may be used to represent nearly all the olives, and a host of other creatures as well, and may be tied in practically any suitable size. For upstream olive imitations I would suggest 16, 14 and 12. I prefer relatively short shanked straight eyed hooks without exception for these flies, for the reasons already outlined above. Small neat sparse flies are more effective than large or bushy examples.
WINGS. - Hen Blackbird or dyed Starling. Light or dark undyed Starling may also be used if desired. This fly is also often winged with grey Duck primary or secondary quill slips, especially commercial ties, but these are rather coarse for this purpose in my opinion.
BODY. - Well waxed primrose yellow silk, which should turn a translucent green olive colour when waxed, there are a number of suitable waxes available, pure Beeswax works, although it is a little difficult to use on silk, Gehrkes Fly dressing wax is also very good, and dubbing is easier with this than with pure Beeswax, if one desires to use wax. "Cobblers" wax is often mentioned in old dressings, but as this comes in all shades and colours from white to black it is sometimes difficult to know what is meant by this. For most of my waxed silk flies, I wax the silk with beeswax, and use a glue stick for “touch” dubbing
It is fairly obvious that very dark or highly coloured wax would change the body colour too much, and there would be little point to this. Some flies are made like this though, using very dark cobblers wax to darken the thread. The ideal wax should usually darken the body somewhat, change the silk colour to the required shade, ( in this case olive), and give the translucence mentioned, or at least the appearance of it.
The body of this fly is ribbed with four turns of fine gold wire or tinsel. (wire is better, lasts longer!) I do not suppose that trout count the turns of ribbing, and it is presumably immaterial whether one uses four or five turns, however the turns should be even and correctly spaced to represent the segmentation on the body of the naturals, and to give a conservative amount of "flash" to the body, which also aids in faking the insects natural translucence.
LEGS. - Dark Furnace hen hackle. Greenwell for lighter flies. In many patterns of this fly Cochybonddu Hen hackle is specified, this is more or less impossible to obtain, in fact many authors and dressers maintain that this colour does not exist as hen hackle. This is not true, I have some natural Cochybonddu Hen hackle, but it is extremely rare. For some patterns "Henny cock" is specified.This is cock hackle with a lot of web and very soft in texture, and is more or less useless for normal dry flies, but may be used on lots of wet flies. The original Greenwells Glory, ( If it was an original! There were similar flies extant at the time) almost certainly used furnace hackle.
THORAX. ( where appropriate ) - Mixed dark Hares Ear fur. Or somewhat lighter when a light coloured wing is used. This may be varied of course to suit the insects on your water. It is essential to blend the fur properly to gain the maximum effectiveness, using single colour substitutes, whether natural or artificial makes a poor fly.
At least three shades should be blended together to obtain the end shade desired, the more the better. In this case a fairly dark shade is obtained by putting more dark fur in the mix. The actual colour which results, is not nearly as critical as the fact that it is made up of different colours. Other furs may be blended in if desired to obtain specific results.
Many old time dressers had "secret" dubbing mixtures which were handed down for generations. Most of these were simple blends of various furs, usually two or three, sometimes more. The "Rythmical Table" describes some of these blends if you would like to try them.
Avoid dyed furs if you can, they are simply not as good as natural blends of fur. For some blends you have no choice, when for instance crimson or bright green or purple is called for, but if possible stick to natural colours as much as you can. Small amounts of synthetics such as antron etc mixed in to give a bit of sparkle, or imitate air covered wing cases, etc seem OK, but don't overdo it, and try the originals first before you start modifying!
HEAD. - Either the waxed yellow silk, or a black or dark brown varnished head. I like black or brown varnished heads on some of these flies. Many of the naturals have very dark shiny heads.
There are countless other variations which alter the appearance, properties, or imitation value of these flies, but these are the main ones. I will try to add some of the various other styles in the near future.
Bunched and rolled wings may also be used either single and paired or split, or even completely different or artificial materials like Antron etc. An extremely interesting new idea for soft hackles is the use of CDC as wings, thoraces etc. I am experimenting actively with this technique, and it looks very promising indeed.
Combinations and variations of each method are also legion, depending on what the inventor wishes to achieve. Hackle and wing angles, body lengths, etc. may all be varied at will. Bear in mind, we have only discussed one fly, using the same materials for the different styles, and the possible variations of wet imitations for various purposes and conditions!
( Cont'd next post )
Mike Connor
Re: Fly styles
Post by Mike Connor » Wed Nov 23, 2011 2:36 pm
Substituting materials extends the possibilities even further into the realm of unknown infinity. Before you substitute materials or modify patterns you should be clear what you wish to achieve by so doing. Adding or modifying things just to make them look different in the box is usually a complete waste of time as far as practical fishing is concerned and even fairly minor changes may render a successful fly useless. You may of course get lucky and find a variation which is even more killing than the original, but this is rare.
Many flies, including the Greenwells Glory discussed above,may be used to imitate quite large numbers of various insects and other creatures under variable conditions, although this fly was of course originally dressed to imitate olives. Other patterns, as is mainly the case with many of the North country soft hackles, were originally designed to imitate a specific insect under certain conditions, when dressed and used in a particular way, at a certain time of year when such insects were extant. They are often not particularly successful when one deviates from this plan, although they will still often catch fish, the results are nowhere near as good as when the flies are dressed and used correctly at the right time.
Nearly all the various lists in the older books, have lots of fly patterns which are very similar indeed to one another. They use the same hackle, merely varying the body, sometimes only very slightly. There is not really much point in carrying all such variations, even if it were possible! Best to choose a core of patterns suitable for your own waters, which reflect the insects to be found there, and stick to these.
More and more dressers nowadays tie from books, and quite a few are not even aware of the actual appearance of the insect they are trying to imitate. Try to collect or at least look at a few of the insects on your local stream or lake, and copy them yourself with the material and skills at hand. This is much more satisfying, and usually a lot more successful than slavishly following recipes from books, at least it guarantees that you are trying to imitate something that is actually in your water, and not something originally designed to imitate lesser spotted black backed dung beetles for perch fishing on the Nile!
Also it is as well to remember that some patterns are tied to mimic insect behaviour when fished as designed, and may not look much at all like the insect itself out of water, this important point is unfortunately often neglected in books of pattern descriptions. Do not be afraid to modify standard patterns to suit your local waters if necessary, nothing in fly dressing or fishing is carved in stone!
Presumably all fly fishing started as a result of attempts to imitate creatures which the fish were seen to be taking, and mainly because of the difficulties of using the creatures themselves as bait.
The first known references to this by Aelian;
http://www.flyfishinghistory.com/aelian ... _trans.htm
Quite obviously give a description of dry fly fishing.
This alone indicates that "dry fly" fishing was probably the first method invented. There is also considerable evidence for this, notwithstanding some writers who maintain it developed later. Their arguments are however illogical, and contradictory. Little more than speculation based on supposition.
Many traditional methods were a cross between dry fly fishing, and fishing minimally subsurface
The size and sparseness of the dressings was to more accurately imitate the insects, and not to "get them down", as is often maintained. The widespread practice of dressing small patterns on larger hooks was a result of often poor hook quality, and the better holding power thus obtained. Fish were not "played" in the same manner as today. When fishing nine flies on a gut leader, it is quite impossible to "get them down" at all, and they all fish merely inches below the surface. The drift duration using traditional gear on running water also does not allow flies to sink any distance, before being lifted off and cast again. Even downstream fishing will not allow this, as the flies begin to "skate" quickly, even in relatively slow water. One can not even cast such a leader with modern gear, much less have any sort of control over it. Many authors have written that the best chance of a fish was when the flies alighted on the water, and before they sank. Although the flies still caught fish when slightly sunk.
While we are on this subject, do not be afraid to substitute materials if necessary, it is unlikely that the fish will notice, this is not always the case, some patterns must be tied with the materials used by their originators if they are to be successful, but there are not as many of these as one might imagine. In general if the properties colour and texture of the substitute material are similar to the original then use it!
However, if you sell or publish patterns originated by someone else you should either do it correctly, or not at all. If you alter someone elses pattern then you should make it quite clear that you have done so, what you have altered and why. It is a very sore point with me that many people publish or tie other peoples patterns and do it wrongly! Some of the commercial ties of successful patterns are abominations, and have little or no resemblance to the originals which were the result of much careful work and thought on the part of their inventors. This is one reason why many do not then work very well.
Modern manufacture of flies by trained commercial fly dressers has resulted in considerable standardisation of types. Many wet or dry flies are dressed identically just with different materials. This is especially prevalent with winged wet and dry flies and nymphs. If you dyed them all black you would not be able to see any difference between them!
This is a major fault! Most of these flies were originally tied to represent specific insects, and the set of the wings and hackle or wing cases etc and the general proportions were designed to do just that. Tying a cinnamon sedge as a double split up wing dry fly may be an interesting tying exercise but the result however beautiful or interesting can not by any stretch of the imagination be fished as a cinnamon sedge and it is a fair bit of cheek even calling it by the same name as the original.
Ignore people who tell you either verbally or in books that flies have to look just so, or that proportions have to be just so. This is completely false, look at a few insects, some have short legs, some have long legs, some have large wings some small, some have thin bodies some fat, some have antennae some do not etc, variation and diversity are the key notes, not standardisation.
It grieves me sorely when some experts go to great lengths especially in instruction books or in so called fly dressing competitions to propagate this nonsense. The judge of your work should be the trout and your own common sense, if your flies catch fish, as they will, then they are excellent, and do not let anybody tell you differently! If you tie flies for display or other demonstration purposes then you must perforce adhere to the rules of that particular persuasion, this has little or nothing to do with practical fishing however, which is what we are concerned with here.
If you "invent" flies by the way, (every tier does at some point!) try to avoid publishing the results until the fly has caught at least fifty fish under repeatable conditions. A glance through the angling press will show you that at least 500 flies per week are "invented" and praised as being the best thing since sliced bread. The very sight of some of these incredible and mostly useless often plastic concoctions obviously constructed with little or no thought, just because some bright flashy stuff was available, is enough to drive any self respecting fly angler back to worm fishing! I would be ashamed to have some of these monstrosities in my box, let alone fish with them.
I venture to suggest that most of them return to the oblivion from which they doubtless originated within a week, which is a good thing too! Most of them just add to the confusion and hype which has to be waded through before reaching that eminently desirable and exalted state of informed grace we are all continually striving for! Occasionally a useful pattern does emerge however.
If you invent a good pattern and wish to publish your results it is not a lot of use to other dressers when you inform them that the main material for your "John Smiths and his mother-in-laws absolutely infallible trout tickler and perch panacea" are only obtainable from the nether parts of a certain type of mountain goat which is the last member of its species, and lives on the slopes of a remote mountain chain in outer Mongolia, and which your mother in law brought home for you after her last mountain climbing expedition.
You might instead consider a name which says something about the fly or the materials used, or what it is supposed to imitate, no matter how insulted your mother-in-law may be at not being honourably mentioned.
Even if your fly is all you claim for it, not many are going to be able to tie it. And what is even worse, should the fly actually be successful, this is invariably bad public relations for conservation minded anglers, as some greedy fool will probably actually go there, kill the goat and proceed to sell the material at an outrageous price.
For similar reasons you should explain how the fly is fished and under what conditions, and if possible the area where it is most useful. You do not have to reveal your best fishing location, (honey hole is the charming American term I believe!) but you should at least be able to give some pointers to the type of water and fish to be caught with it.
Adding gold beads or tinsel or pre-formed plastic waggle tails and the like to well known standard patterns does not in my humble opinion constitute invention, it may increase the catching capability of some flies but in my experience the reverse is also often the case. Furthermore putting heavy gold beads or lead wire on upstream wet flies, or even dry flies which I have seen lately (God knows why!), renders them absolutely useless for their original purpose, they may or may not catch fish but this is not the point at all. The greatest satisfaction to be had is discovering what the fish are eating, mounting an imitation of this creature, and by artful and skilled presentation fooling the fish into taking it.
Dragging a lump of nondescript weighted plastic through a deep pool on the end of a high density sinking line is not really fly-fishing, however many fish may be caught by doing it. Catching a limit of mentally retarded fin damaged and hand tame rainbow trout in a put and take lake on a royal coachman during a hatch of medium olives is not fly-fishing either. If you enjoy it and want to do it and it is allowed on your water then go ahead, but do not fool yourself into thinking you are fly-fishing. You may catch a lot of fish but you have missed the point entirely and are not getting the satisfaction you ought to from this magnificent pastime.
http://www.archive.org/stream/wayoftrou ... 7/mode/2up
This is a plate from Skues' book where he also bemoaned some "standard" stuff.
You can download some of his books here for free;
http://www.archive.org/search.php?query=Skues
Style used to mean the way flies from certain areas were dressed for specific purposes, some well known styles were from the Tummel, Usk, Tweed and other Scottish and English rivers. Nowadays it has come to mean the little idiosyncrasies that well known tiers build into their flies making them instantly recognisable. This can be oversized round highly varnished heads, or over long thin rakish wings, or small sparse beard hackles , or "stroked" hackle, (this is a hackle where the fibres are pulled over the thumbnail after the fly is tied to give them a specific curve, the curve may be varied at will with practice), or other points of recognition, or combinations of such.
This is quite interesting, but basically a fault in my opinion, leading to standardisation of a kind as well. Something I constantly struggle to avoid. This sort of thing is not worth copying. The only sensible reason for a practical fly-dresser exaggerating or otherwise changing the appearance of a fly in this way is if it makes it more attractive to trout. Making flies more attractive to people may be an interesting and even profitable exercise, but it is highly unlikely to catch you any more fish! Which is the object of the whole thing as far as I am concerned.
One last point worth remembering, is that many patterns were tied for specific purposes on specific waters, under sometimes very specific conditions. (The English chalk streams for instance have generated much literature and many patterns.) It is highly probable that they will be absolutely useless on the water you fish, either because their natural counterparts do not exist there, or are not available in numbers large enough to get the trout interested, or because such conditions never prevail on your water.
Fly styles vary very considerably according to region. Many styles are no longer used much, but they still work very well indeed when used for their originally intended purposes! This is largely ignored nowadays. Many people adhering to “standard” dressing styles.
This fly is a "standard" downstream winged wet fly with the wings set down.
These sort of "Standards" have mainly been propagated by professional fly-dressers and many books, over the years, for various reasons. Some apparent and sensible, and some less so, this does not necessarily mean they are the best, or even useful at all in some cases!
Set Down.
Some commercial flies I have seen , especially of this pattern, are absolute abominations, the bodies formed of olive floss and not waxed at all, the tying thread is often black, the thing is then about as translucent as an elephant painted black, and about as delicate.
Set down means that the natural curve of the quill feather wing slips is towards the hook shank, and the wing slips are placed front to front with the shiny side of the feather outside, partially cancelling out the natural curve of the feather, and holding the wing slips together.The wings slant almost parallel to the hook shank, aided by a bed of silk at least the same height as the body windings. The slant of the wings may be controlled by position and height of the wing bed when tying in, and may be varied somewhat if desired. Wing slant or “set”, also varies considerably. Many Scottish dressers use a much steeper wing angle on their flies, usually about 45°.
This winging style has become a sort of standard for many winged wet flies, and these flies are also often hopelessly overdressed, meaning far too much material is used. The imitation value is nowhere near as good as many other styles, although better when kept sparse and neat. The whole fly has a streamlined appearance, the hackle is also tied in so that it slants back at about forty five degrees to the hook shank and usually long enough to reach the hook point and even cover it slightly, although this is again purely a matter of taste, and dependent of course on the size of hook and length of shank.
This fly when dressed correctly will have a good "entry" when cast, meaning it will not cause too much disturbance when it lands on the water, and will sink fairly well, and will cause little disturbance when held in the current, or indeed when "worked," and will maintain its shape fairly well even in turbulent water. The hackle is hen. The wings are tied in last and then the head formed over the roots. The fly really depends on being moved by the current or worked to resemble a living creature, this is unnatural for a dead winged fly imitation, and is basically not particularly well suited to upstream or dead drift fishing, although it may occasionally work for this purpose. In larger sizes it is a good fry imitation. The shape of the wings is in my opinion largely due to a series of mistakes made by various authors, but that requires a separate article and explanation of it's own.
Set Up.
The wings on this fly are set up, and the hackle is not swept back to the same degree. Set up means that the wing slips are tied in with the natural curve of the feather curving away from the hook shank. The slip wings are set at an angle of about 45 degrees, and stand well proud of the body, this angle may be varied. This fly may also be used for downstream fishing, but heavy currents or "working" the fly will cause the wings and hackle to be compressed towards the body of the fly and force it out of shape. The imitation value is then usually not particularly high especially when overdressed, and many people think these flies are taken as small fish or active nymph imitations rather than as imitations of drowned winged insects. They sometimes work well though, and many such patterns have long traditions.
This is a fairly typical upstream wet fly.
The wings are tied in last, and then the head formed over the cut roots. This fly also mostly depends on being worked to resemble something alive, and is also not very suitable for upstream or dead drift fishing although it is somewhat better than the first example. The hackle is hen fairly short and sparse, with the majority of the hackle beneath the hook. A beard hackle (bunch of hackle fibres) may also be used.
An “Advanced wing” style was also popular on a number of dry flies. The most well known of these are probably the Mole fly and the John Storey, but there were quite a few others.
Set Up back to back.
This fly has slender wings, and the slips are not only “set up”, but tied in to curve up and out away from the body of the fly, “back to back”, with the shiny side of the feather on the inside. The hackle is only slightly brushed back when tying in, and the body is kept short and thin. The wings are tied in before the hackle! and the hackle covers the wing roots. The whole appearance is delicate and the fly is a fairly accurate imitation of a living creature. As such it may be used as an upstream or dead drift fly with some success. The Hen hackle is fairly short, sparse, and mobile.
Upright slip, split or bunch.
The fibres are tied in either as slips or in a bunch, and then split.The body is then formed, and the hackle applied last. The appearance is neat and delicate, with a high imitation value. The hackle is hen. This fly is excellent for upstream or dead drift work. It will also work as a downstream fly. Soft translucent feathers are best for these bunch wings. Jay primary or secondary, was at one time very popular for this, as were various duck body feathers. For the greenwell hen blackbird was used, but one may also use starling and other feathers. For small imitative flies fine fibred translucent feathers work best.
This fly is a spider variation with a small fur thorax, and due to the very long hackle and the method of dressing, is an excellent nymph imitation for downstream fishing or working.
It will function as an upstream dead drift fly, but is basically designed to be worked, as the long, backward slanted, radially applied hackle, when pressed back by the current ,forms a translucent, very realistic, and mobile nymph body, shrouding the hook and actual body, giving a good impression of a nymph, or emerger .
These flies have a high imitation value especially for agile swimming nymphs, small fish etc. The hackle is not too sparse, and very long hen, it should project beyond the hook in order to achieve the mobile tail effect mentioned. Only works well when worked. Usually the point fly.
This fly is a spider variation for upstream work, and for dead drift fishing. The hackle is set in a vertical plane, or even slightly forward, (known as dressing with a "kick"), and the small dub of fur behind the hackle holds the hackle more or less in this position as well as the thread finishing process. The hackle is set hard up against the fur ball. A similar effect may be achieved by using several turns of thread behind the hackle after tying in, and thus forcing the hackle forward.
This type of fly is usually worked, either upstream or down. It is extremely difficult to work a single fly successfully, usually some special technique or setup is required
This fly will also often work fairly well as a downstream worked pattern, but the hackle will of course be pressed back by the current in this case, and the fly look more like a nymph than a winged insect, but not as much like a nymph as the previous fly. Also, dead or dying winged insects which this type of fly is usually (but not always!) designed to represent do not normally swim, certainly not against the current, and imitations thereof that do so, are usually ignored by all but young or “stupid” stock fish.
This is the "standard" soft hackle style mainly used nowadays, with an "umbrella" type hackle splayed evenly around the hook, and often swept back at a slight angle, it is sparse and even, with hackle fibres about one and a half to twice the length of the body, which is about two thirds the length of the hook shank. This fly may be used downstream, or worked, and may also be used as an upstream and dead drift fly, although not quite as good as some of the other models for this purpose it will take its share of fish. The hackle is again hen, and has not been manipulated, merely wound in.
Flies dressed with soft hackles show more “curve” than flies dressed with hen hackles, unless they are manipulated by being “set” and “bent”. Also, the stiffness, curve, and thickness of hen hackles varies considerably. Coarse webby hen hackles being better for most such purposes.The type and quality of hackle one uses is also influenced by the intended purpose. For fast water and some techniques, stiffer hackle may be better.
This fly is dressed with cock hackle wound so as to be vertical and concentric to the hook shank, as in a dry fly, the shiny side of the hackle to the back. It may be used in very fast water without the hackle collapsing around the body, and is effective mainly because of the semblance of life engendered by the hackle barbs flickering under pressure in the current. It may be used as an upstream or dead drift fly, but will not be quite so effective except in very rough water, as the stiff hackle barbs will not then move much, and one may experience lots of refusals from fish which turn away at the last split second. These flies were also often dressed with “henny cock”, which is soft cock hackle.
The hackle is kept fairly sparse, but somewhat bushier than a normal soft hackle spider. These flies are sometimes fairly hard to sink as well, and the cast and fly must be degreased thoroughly or this will be a problem. The hackle curve varies according to the feathers used.
A variation of this style using cock hackle, which was set back at an acute angle, was also used for worked flies, usually with fairly substantial dubbed fur bodies. One of the major exponents of this was Cutcliffe. Although this style does work in certain places and under certain circumstances it is not usually as successful as others.
This fly is dressed using combination of cock hackle and hen hackle, the short cock hackle, which is wound in first, supports the hen hackle and prevents it collapsing when worked, or in fast water, this fly may also be used upstream but is again not usually quite as successful for this purpose as a mobile single hen or other soft hackled fly. The amount of hackle and the angle of application may be varied to suit water conditions as desired. The same technique may also be used for supporting other soft hackles of course.
Such flies can be very effective in rapid streams.
This is a spider variation with a thorax of fur and a very short hen hackle, it may be used upstream or down to represent various nymphs, caddis, buzzers etc, a tail may be added, as in the photo, if desired, as the hackle fibres themselves are not long enough to imitate the tails. Short Pheasant tail fibres are good for this, or a small short bunch of coarse hen hackle barbs the same colour as the hackle usually, as they imitate the hairy tails on many nymphs very well indeed. Feathers are of course fragile, and various hair will usually last longer.
These flies may be used up or downstream and dead drift, as they are fairly good imitations, although somewhat lacking in "life" because of the short hackles. They do work well fished just below the surface, when they are probably taken for emergers.This particular spider can be deadly in an olive hatch.
This is a North-country-style spider with the hackle “set” above and below the hook, and "bent" to shape by curving the fibres over the thumbnail. This style is a fairly good upstream fly, primarily imitating spent spinners, but will lose its shape immediately when used downstream or worked. It is purely for dead drift work. The hackles are “set” above and below the hook to represent the wings of a spent fly. This technique was very popular at one time in North country flies. Many dressers being of the opinion that it was a much better imitation of the naturals when dressed in this manner.
This style is not very popular nowadays, it is a reverse dressed fly. The hackle is at the bend of the hook. A theory was advanced by several people that this fly looked more natural under certain circumstances when fished upstream, as it was then "facing in the right direction", the bend and barb are better concealed, and the tippet looked more like a tail helping to disguise the imitation even more.
I do not think much of the "facing in the right direction" theory for wet flies, although it might be true to an extent for floating duns fished upstream, the naturals of which often seem to face upstream, ( although this of course depends on the wind and water conditions).
Any flies may be dressed in this manner. The weight distribution is also a consideration with this style, if using heavy hooks the sink rate and attitude may be bettered when the flies are tied "reverse", the hackle being at the bend prevents the fly from being "tail heavy" as it would be if dressed normally on a heavy hook.
I have tried dry flies dressed in this manner as well, but they tend to be bad hookers for fairly obvious reasons, although quite a few anglers swear by them. The stiff hackle keeping the point covered and only hooking up when the fish closes its mouth thus compressing the hackle and the strike occurs at precisely this moment, in all other cases the point is masked by the hackle and the fish is not hooked. This is not a serious consideration with soft sparsely hackled flies.
This is a semi-palmer or "buzz" hackled fly. “Buzz” also means dressed without extra wings, just using a hackle. This is the style favoured by Stewart for his famous spiders, ( which were actually from Baillie), and it works exceedingly well for upstream flies, especially ones with very mobile soft hackles like Starling. It may be used with other hackles as well though. I use quite a range of spiders in this style, especially on the “long rod”.
This particular Greenwell Spider is one of my favourites, and I have caught a lot of fish with it. The well waxed silk is taken down to where the body should start, the gold wire is tied in and left hanging, the silk is taken back up almost to the eye of the hook, where the hen hackle is tied in, this is palmered half way down the body, and then ribbed with the gold wire. The head is finished as normal after tying the gold wire down. ( Stewart advised a particular method for dressing spiders. I mainly use the above method because the flies are more robust).
This is probably the most mobile and versatile spider style of all. Good as a “general” fly, but also excellent for matching the hatch for, nymphs, emergers, drowned duns and spinners.
The method originally described By Stewart for his spiders, which had no wire ribbing, was as follows: The hackle is tied in at the shoulder by the base of the feather. Then the silk and the hackle are pulled up together above the hook and the feather twisted around the silk. Then the hackle and thread are palmered together toward the bend of the hook until the feather runs out, , or to where one wishes the hackle to end. The thread is then carefully brought up the body, ribbing the hackle again, and tied off at the head.
Yet another method, is to wind in the body. Take the silk to the eye, and tie in the hackle by the butt. Take the silk in wide turns back down the body to where you wish the hackle to end. Wind the hackle down the body to the same point as the silk. Now rib the hackle back up to the eye, tie off and whip finish. The excess hackle ( if any) may be twitched out, or cut off. This is useful if you don't want to use a wire rib.
These are just a few styles there are many more variations and local "tweaks". Which style you use should be chosen to suit the conditions and your fishing methods.
TL
MC
Re: Fly styles
Post by willowhead » Wed Nov 23, 2011 2:49 pm
See there..... :D ..... :lol: ....."Ya did it again....." ;) Tkx. Mike.....you dah main. 8-)
Re: Fly styles
Post by CreationBear » Wed Nov 23, 2011 3:06 pm
Much to digest here, but since I'm on a Leisenring/Hidy kick right now, I was really intrigued by your take on dubbing--especially the importance of blending different natural shades. Do I understand correctly that you think it's more important to provide a "full spectrum" of colors rather than trying to reproduce what we ordinarily call the natural hue of the organism we're trying to imitate? Given all the complexities of light we encounter streamside, it might make sense to hedge our bets! :)
(BTW, I'm also very curious about this "Rythmical Table" business, though it sounds like something one might attribute to Hermes Trismegistus. :lol: )
Mike Connor
Re: Fly styles
Post by Mike Connor » Wed Nov 23, 2011 3:33 pm
Not a "full spectrum" but definitely a mix. The mix should be as close as you can get to the natural insect colour. Flies with mixed dubbing are invariably more effective.
With regard to the "Rythmical Table" here it is;
Ettingsall’s Metric
Dubbing is a fascinating subject. It is true that some dubbing mixes are much better than others for some things. Many modern single colour synthetics, and similar stuff, are greatly inferior to natural dubbing mixes. There is no limit to the lengths one may go, in order to obtain first class dubbing. Shaving ram´s testicles being one of the easier and more innocuous methods. Many people over the years have tried to help in remembering what feathers and dubbing to use, and when to use the resulting flies.
Here is an interesting epic from a famous Irish angler who is renowned, among other things, for the fact that he knew of and used a floating fly for trout in the early 1820´s, almost twenty years before any other known angler. He obviously knew his dubbing as well, as you will see if you read carefully. As my copies of the table were all missing parts, this work has been taken in its entirety from the book "Irish Trout and Salmon Flies " by E.J.Malone. A very nice book first published in 1984, and rather hard to obtain since then! I assume no copyright exists for the table, as it was first published in the 1800´s.
RYTHMICAL TABLE
"Of the principal flies for angling , and the season in which they should be used ; communicated to the editor by the ingenious MR. THOMAS ETTINGSALL, proprietor of the sporting tackle establishment, Woodquay, Dublin."
"Of various flies that sport upon the wing,
Their angling seasons and their names I sing. " PETRUS PISCATOR
From age to age the rural pastimes grew,
Necessity first urged, then pleasures new
From wants supplied arose, and none more pure,
Than from the deep the finny tribe to lure:
The high , the low, the simple, and the wise
Make it a study how a trout to rise.
The pale mechanic hails his holiday,
And to the gurgling streamlet speeds his way;
There in the lonely vale,to praise his God
And seek contentment from his pliant rod ;
At eve returning with his basket´s store,
And health renew´d for six days´ labour more.
O! where on earth is pleasure so secure
From every ill to rich as well as poor.
As is the angler´s free from harmful guile ?
To take one sporting trout he´ll trudge a mile,
Marking the flies that sail adown the brook,
Then try to match them from his fishing book.
Philosophers, with rod, may rove the stream,
To contemplate on nature´s wondrous frame;
The monarch may forsake his cares and throne,
And seek the silent vale and brook alone.
One tumbling trout will give him more delight,
Than all the state which dazzles others' sight;
The youth will cheerfully his books resign,
For health and pleasure with his rod and line,
From Greek and Roman lore awhile to rest,
And learn to tie the fly will please the best,
How he may read upon the varying skies,
From thence to judge the order of his flies;
How he may place them on his trailing link,
Know which should float, or which should partly sink;
And next to know the feeding hours that trout
Are most accustomed to, or frisk about;
And of the varying winds to know the best,
And at what side the brook his game may rest
These, my design to lay before his eyes,
In due succession, and the killing flies;
The less approv'd I mean to set aside,
And name but those by long experience tried;
To imitate their structure with due care,
Beasts must contribute and the birds of air,
Cock, partridge, grouse, the fox, and timid hare,
Materials he from winter's sports shall find,
To furnish well his hooks, and cheer his mind;
The wren, itself, tho' smallest of his sort,
Contributes largely to the angler's sport,
His tail, as hackle, in all winds that blow,
Atrout will take, for if the river's low,
a spider wren, a muscle's beard the frame,
Or dark brown olive mohair, much the same,
Will draw the scaly epicure from where he lies,
Sick with lukewarm stream or gorg'd with flies,
The hackles of the cock, red, black, or grey,
Form flies to kill from March to Lady-day;
The fox's skin will many shades produce,
Nor is his beard, for forking, without use;
The grouse is good, but that of deepest black;
Gives the best hackles from his dusky back;
The hare is wanted only for it's ears,
The fur of which the greatest value bears -
This, mixed with orange, yellow, black, or green,
On lake or river better ne'er was seen,
With mallard fork, and silver ribb'd or tipt,
The wings from starling or from mallard stript;
The hare's-ear tipt most excellent you'll find,
It forms a fly the best of all it's kind;
The sooty black will constant sport produce,
And, in the evening late, comes into use,
And now proceed we to recount the flies
That in their months will cause a trout to rise.
FROM 14TH FEBRUARY TO 14TH MARCH
The vernal breezes, with boreal blast,
Now struggle 'till the latter is out-cast,
The finny tribe make to the shallow streams,
From deeper water, to recruit their frames;
The genial spring new insects now create,
Their food to seek and be for others meat,
Hare's-ear and claret mohair, partridge wing
Mix'd with the stare, the vernal breezes bring;
The dark dun-fox is seen to cut the air,
And great brown coghlan called by some brown bear
A dark-red hackle, orange body tied,
Will surely win the river's scaly pride;
A jet-black hackle on the foot-link's tail
With purple body tipt can never fail -
And mark, all flies that are of sombre hue,
In early spring more certain sport will show,
And the brown coghlan near to Patrick's day
Like modern statesmen, turns his coat to Grey.
FROM 14TH MARCH TO 14TH APRIL.
The sun's increasing heat, and southern gales,
Still more and more against the cold prevails,
And kindly showers, mixing with the brook,
Dispel the chill - then on the waters look,
There you will see the grave hare's-ear, unmixt,
Floating the stream, or on the eddies fixt;
The brown rail too; the light and dark blow-fox,
And hackles from the grey and tawny cocks -
They end in March, but, if the month's severe,
They never show 'till April's softer air;
But let this rule be held by every man,
For ever hold the black cock, red, and wren,
As never-failing food - the common bread
On which the tribe of trout are fed;
You may adorn them round about with gold,
May change their wings reverse to nature's mould,
But the red hackle shows still at the breast,
And so it is with black wren, and the rest.
FROM 14TH APRIL TO 14TH MAY.
'Tis an old saying, and 'tis truth they say,
That April showers bring forth the flowers of May;
And every flower that blows gives fragrant birth
To many creatures scarce perceiv'd on earth:
Each shrub and plant possesses in its kind,
The various beings that sport upon the wind.
No sooner does the cowslip burst its bell,
Than the cream camel leaves its golden cell;
The clover which the cow delights to taste,
When pass'd again, brings forth a tribe in haste,
The lady-cow is seen to flaunt about,
As any lady at a ball or rout;
But very soon she changes her green suit
To dusky yellow - orange - and at last
Hare's-ear and yellow is its destin'd cast;
The gosling fox, too, seems its nearest kin -
But hark! the cuckoo's note - sweet May comes in
The yellow meads with cowslips studded o'er,
Send forth their natives to the pebbl'd shore.
The yellow May-fly wings o'er brook and lake,
The harbinger of the stone-prison'd drake,
The black-bank spider and the sooty black,
The golden olives show a wat'ry track,
With golden, sooty, and the meally grey,
Are all good flies throughout the month of May.
FROM 14TH MAY TO 14TH JUNE.
Now Nature is accouch'd - each shrub and tree
Receives to nurse, her latest progeny -
The order of the insect world's complete,
As the sun's course attains meridian height.
Emerging from the deep recesses of the lake,
Upshoots the pebble-cradled soft green-drake;
No sooner does it meet the atmosphere,
Than with its lustrous wings it courts the air.
Its morn of life is gilt by its own ray,
But soon its bright embroidery wears away
To sickly green, deep buff, and last to grey.
Next look along the silver-pebbled strand,
The stone-fly skips, from stone to stone, to land,
As if (like cats) it fear'd to wet its feet,
It pauses ere it leaps, although its leaps are fleet.
The sun's meridian brings another feast
To tempt the epicure - the over haste
Of the industrious ant, returning home,
A rising wind drifts them amidst the foam
That dies away, a summer show'r takes place,
That o'er, a mist of midges strikes your face.
The blue-blows with their copper legs are seen,
The sooty midge, white gnat, and gosling green;
The orange cow-dung, olive camels too,
All fork'd none tipt, but every shade and hue,
On a good feeding spot if you cast out,
Will scarcely fail to rise a sporting trout.
FROM 14TH JUNE TO 14TH JULY.
Before Aurora opes her curtains wide,
Speed from your bed unto the river's side;
The flowers' wing'd inmates are confined with dew,
Seize on their absence, 'twill be best for you -
Foro,when Sol's chariot tops the hill of noon,
The trout looks to his rays and promised boon,
The dew dries up, the fragrant prisons ope,
And all the captives from their cells elope;
Each whispering breeze will waft across the brooks,
The food for which the trout expectant looks,
As drifted to his mouth he basking lies,
So gorged he shuns your shade and scorns your flies
And all your art will fail to make him rise.
Then take the morning as I said before
Doubt not your basket will contain a store -
The golden harvest wags it's yellow beard,
The twittering quail and corn-creak are heard;
The Naids quit the shallow sun-dried brook,
The trout exhausted seeks some hiding nook
Some little pool beneath a rock or bank,
That scarce conceals his back within the tank
He there lies pent, nor dare he rove for food,
But watchful nature in her care is good;
The caterpillar up the sedges crawls,
In spite of all his legs, he reels, he falls
Into the mouth that's waiting for his fall,
A sweet repast at angry hunger's call.
FROM 14TH JULY TO 14TH AUGUST.
Tis then you may deceive him while his eyes
Are fix'd with hungry look upon the skies;
The flies to use are these I recommend,
A jet-black hackle at your foot-link's end,
The body, deepest blue, the tail, tipt gold,
The wings, light stare, next in esteem I hold
The golden ash and tied with yellow silk,
The wing the creamy tint of stripping milk;
The next, a spider wren with yellow fur,
Must move a trout if he's inclined to stir.
A hawthorn black, then, as the morn grows old,
Which how to tie I cheerfully unfold;
Pen-feathers of the jay the wings compose,
Black ostrich herl along the tail lay close,
Until you reach where you design the breast,
Which must be formed of the green plover's crest;
Then o'er the ostrich herl be closely laid
The blackest horse-hair, and the fly is made;
Nor e'er forget mixed hackles, black and red,
The Soldier-fly with dark and ominous head,
As suit it's name it is a slaughtering fly,
Struck by it's barb full many a trout shall die.
Now breakfast o'er as it approaches nine,
Get out your dapping link both long and fine,
Your horn stock'd with blue-fly, and the oak
Called the down-looker - rest yourself and poke
Beneath some tree that over-hangs the pool
Where no breeze ripples, there a glutton fool,
Some bully trout, that scorns a puny fly,
May take your dap and like a glutton die.
Now as the yellow corn moves to and fro,
Like ocean's waves, the water reeds also
Bend to the breeze and from the nodding blade
The flag-fly tumbles and a prey is made-
But let us now direct the angler's eyes,
Unto the order of the day and flies,
The orange palmer and the yellow too,
The flag-fly orange, and the slatish blue,
The shaggy caterpillars red and black,
The light cream camel and the soldier-hack,
These in the morning on the pools he'll find
To please the trout, provided there is wind.
When evening comes and clouds move o'er the skies,
The trout are seen on every pool to rise,
Prepare the foot-line, fine, and round, and clear,
And let it these three smaller midges bear -
Scare-crow, magpie, ostrich or white gnat,
With hackles black and red, and you'll find that
With these you'll rise, unless the sun sets bright,
Then look to moths and hoppers for the night.
FROM 14TH AUGUST TO 14TH SEPTEMBER.
Now Iris bends her bow across the hills,
And looks with pity on the low sunk rills,
Betimes she weeps, then smiles, then weeps again,
Until her intermitting tears o'erflow the plain,
And, sudden rushing down it's ravine bed,
Swells stream and river to the sedges' head,
And as it drives along it brings such food
As worms. and snails, and all the creeping brood:
To cast a fly is useless - bait is best,
Altho' pot-fishing sportsmen should detest:
Yet, rather than return with sullen brow,
The brandling worm or black-head I allow
Are very good - but if the water clears,
The rising trout the angler's spirit cheers -
Put up a black and orange tipt with gold,
An orange palmer, altho' growing old;
Hare's-ear and yellow, hackled at the breast
They are the killing flies if rightly drest;
But if with these you cannot stir a trout,
A good black-hackle silver'd round about,
Placed on your foot-link's end, and next to that
The fly called yellow mixt with fur of rat;
The next a fiery brown with partridge breast,
Or red or golden wren, as you think best,
Will kill from mid-day 'till the sun goes down,
When 'tis full time you turn your face to town.
But hark! what noise is that? 'tis from a gun,
The twentieth 'August calls to other fun -
A grouse is down, the trout too hears the noise,
And close among the rocks he torpid lies;
There let him rest until his fright is o'er,
Then try him with another cast once more.
FROM 14TH SEPTEMBER TO 14TH OCTOBER.
Now autumn's hollow blast howls o'er the plain,
The farmer from the field draws home his grain;
The whistling winds the sickly trees now shake,
Down drop their yellow leaves on stream and lake,
Like rafts, they carry down the living freight,
The last repast to trout of insect meat.
The insect world is passing swift away,
The fly brown in the morn, at eve turns grey.
Look to the month of March, and recollect
The order of the flies you should select,
Two more 'twere well you add unto that list,
The grouse and woodcock ribb'd with golden twist;
But if the atmosphere continues light,
Throughout October trout at flies will bite;
For as the fly grows scarcer ev'ry day,
The fish more easily become your prey.
Some flies there are, which yet we have to name,
Tho' claiming less of gen'ral rank and fame
The blue macaw, with purple body tipt
The hackle black, or red without being elipt
Some call it Wellington, some Waterloo,
For at that noted time it comes to view.
The snipe and partridge too, afford good flies,
And the grey-plover's hackle we should prize.
Angling now o'er, lay by your rod for good,
In vain you'd tempt the trout with insect food;
For Nature now provides what best agrees
With their soft pregnant state as fit she sees,
And would you Nature's kindly care assist,
Make the fell poacher from his arts desist.
The nets and faggot-lights, and spears by night,
Which devastate the spawning streams, and blight
The angler's hopes, when vernal airs return,
O'er river, lake, and primrose-bordered burn;
When past is winter's stern and frigid reign,
And grove and mead fresh clad, smile forth again;
When Nature's harmonists rejoicing sing
Their praise of HIM who gives renewing spring.
NOTE As the pleasure and success of the angler depend principally on the goodness and unfading property of the colours composing the dubbing, or bodies, of his flies, the Editor has pleasure in acquainting his readers, that MR. ETTINGSALL, to whom he is indebted for the foregoing excellent metrical instructions, has discovered a mode of dyeing colours, which, for sparkling brilliancy and retention of their hues, has not yet been equalled."
I hope you all enjoy this interesting table, it gives considerable insight into the furs and feathers in use at the time, especially with regard to dubbing colours.
TL
MC
Re: Fly styles
Post by CreationBear » Wed Nov 23, 2011 4:20 pm
Outstanding...I'll have to make crib sheet to keep on my tying desk. :) (BTW, Mr. Ettingsall wasn't a half-bad poet--no Gerard Manley Hopkins, maybe, but he probably caught more fish.)
Mike Connor
Re: Fly styles
Post by Mike Connor » Wed Nov 23, 2011 4:58 pm
CreationBear wrote:Outstanding...I'll have to make crib sheet to keep on my tying desk. :) (BTW, Mr. Ettingsall wasn't a half-bad poet--no Gerard Manley Hopkins, maybe, but he probably caught more fish.)
Don't know whether he caught many fish, but he liked trout;
Pied Beauty
Glory be to God for dappled things—
For skies of couple-colour as a brinded cow;
For rose-moles all in stipple upon trout that swim;
Fresh-firecoal chestnut-falls; finches’ wings;
Landscape plotted and pieced—fold, fallow, and plough;
And áll trádes, their gear and tackle and trim.
All things counter, original, spare, strange;
Whatever is fickle, freckled (who knows how?)
With swift, slow; sweet, sour; adazzle, dim;
He fathers-forth whose beauty is past change:
Praise him.
Gerard Manley Hopkins.
Re: Fly styles
Post by willowhead » Wed Nov 23, 2011 6:05 pm
WWWWWWWWOOOOOOOOOOOOOOWWWWWWWWWWWWWWWWW!!!!! Farm Out man...............wwaayyyy farm out. :D ;)
Re: Fly styles
Post by CreationBear » Wed Nov 23, 2011 6:26 pm
Ha...Father Hopkins was really in a league of his own--too bad he never made it to America to see our vermiculated brook trout. :) FWIW, Ettingsall is part of long line of what you might call "georgic poetry" that extends all the way back through Virgil (of course :) ) to Hesiod. Up until the 18th century, before the likes of Jethro Tull and Arthur Young brought a little science to agriculture, well-bred Englishmen were still using Virgil's "Georgics" as a kind of farmer's almanac to tell them how and when to plant and harvest. Not surprising that Mr. Ettingsall still has something to say for us fishermen.
Mike Connor
Re: Fly styles
Post by Mike Connor » Wed Nov 23, 2011 6:41 pm
Here's one of mine, although I hesitate to post such in the same thread containing work from Manley Hopkins;
What does one use, when trying, really excellent flies to dub ?
where may it be obtained, from what , and how? Aye there's the rub,
some flies may well be tied with fur from various coloured cats,
but by far the better bodies, are those made from common rats.
Also useful are the furs from squirrels moles and shrews,
these will provide essential browns and reds, and even greys and blues,
Water rat and beaver, muskrat, mouse, and water dog,
provide the finest hair and fur,which when wetted, will not clog.
Coypu, camel, pig, and hedgehog, and pubic hair, from rams,
Andalusian virgins are also good, (you must remove the wams),
Red bearded beggars, new born seals, and of course great polar bears
all these things you must procure, if you wish to tie with hairs.
Before you venture out at first, to lay up your treasured store,
read lots of ancient angling books, full of arcane lore.
Your stomach must be strong it's true, and your gorge be well controlled
When skinning voles and rats, and mice and cats, you must remain quite cold.
The furs so got, are of the best, and tie the finest flies,
and may be improved even more, by judicious use of dyes,
Picric acid, turmeric, carbol , and urine from an ass,
obtain them all, and store them well, they will all come to pass.
Should you desire at some far future date, the fair sex to espouse,
conceal your horde most carefully, or it may her ire arouse.
Especially the andalusian stuff, if found may cause some strife,
but even harmless things like donkey piss, can also cost a wife.
Explain the needs for all these things, before your wife you wed,
or you may discover far too late, that she has a stubborn head.
Choose carefully brother piscator, but not quite as for fur or dyes,
You can always get another wife, but not always excellent flies !
TL
MC
