Tavy Terror
- Hans Weilenmann
Tavy Terror
The Tavy Terror started its life on the river Tavi, in the county of Devon, England. It quietly made its way north, across the border with Scotland - to spread 'terror' among the loch browns...
Tavy Terror
Hook: Grip 12804BL #14 (or equivalent 1XL wet fly hook)
Thread: Benecchi 12/0, black
Hackle: Hen, greenwell
Rib: Wire, gold fine
Body: Tying thread
Tavy Terror
Body: Tying thread
Re: Tavy Terror
I like the pattern quite a bit. The colors are nice compliment to each other.
Re: Tavy Terror
Hans on the lochs was the Tavy used to represent a midge?
Re: Tavy Terror
From the name and the description of how the name came to be, if one had a few of these and a few of the Alexandra pattern in ones fly box, not a trout that has had water pass through its gills would be safe!
Nice to see that antique flattened wire in use again.
Exemplary tie, as per your usual, but are you sure that is not a light furnace hackle?
Re: Tavy Terror
Hans, it's like a softer, gentler Williams Favourite. This would make a fine midge pattern, but as a loch fly it may be a bit trim compared to it's older cousins. Exceptional photo of this hackle's subtleties.
Re: Tavy Terror
Funny you would say Midge pattern. I tyed a few this morning in size 20, 3906 hook.William Anderson wrote:Hans, it's like a softer, gentler Williams Favourite. This would make a fine midge pattern, but as a loch fly it may be a bit trim compared to it's older cousins. Exceptional photo of this hackle's subtleties.
I am going to tie some up on a size 18, 9671, or 3399 hook, give it some sort of tail, and use it for Small Winter Stone Nymphs.
- Hans Weilenmann
Re: Tavy Terror
From my contact in Scotland who put me onto this pattern:William Anderson wrote:This would make a fine midge pattern, but as a loch fly it may be a bit trim compared to it's older cousins.
"We have found it hugely effective on the lochs here. I also tie it with a wire body, 2 strands of black one of gold. This is effective early and late in the season before the water warms up or when it cools. As I have to keep several friends supplied with these I end up tying 6 or 7 dozen a year."
