Bronze & Peacock
Hans Weilenmann
Bronze & Peacock
Post by Hans Weilenmann » Thu Nov 19, 2009 6:48 pm
Bronze & Peacock
Hook: Kamasan B175 #14
Thread: Benecchi 12/0, 12
Hackle: Bronze mallard barbs
Rib: Fine copper wire, orange
Tail: Bronze mallard barbs
Body: SLF Prism #194 (peacock); mole, natural - into split thread
Re: Bronze & Peacock
Post by DOUGSDEN » Fri Nov 20, 2009 8:21 pm
Hans,
That's electric! I bet it glows underwater! I really like the overall look of the fly!
The dark mallard is excellent!
Post by letumgo » Fri Nov 20, 2009 8:37 pm
Gorgeous fly, Hans.
gravelbed
Post by gravelbed » Sat Nov 21, 2009 4:53 am
Hans.....
You decribe the hackle as " Bronze Mallard Barbs" are these tied-in as a bunch and some how rotated around the hook shank ??.
Hans Weilenmann
Post by Hans Weilenmann » Sat Nov 21, 2009 5:05 am
gravelbed,
Close. After attaching the thread I fold the strip of barbs (or a bunch of barbs or hair for that matter), tips pointing over the eye of the hook, around the shank. Make a loose loop all around shank and material and tighten. Some fine tuning can be done at this stage, but mostly the hook will be fully and evenly encircled. Cinch and secure with a couple tight wraps.
Better make sure the length of tips exposed is the length you want, as there is no going back afterwards :twisted:
Complete remainder of fly, fold back collar and fix angle as desired. Whip finish... done 8-)
gravelbed
Post by gravelbed » Sun Nov 22, 2009 8:50 am
Hans.....
Referring to "I fold the STRIP of barbs....... I take it that you actually cut a section of the feather containing enough fibers required, fold this around the hook-shank to the correct proportions, then catch-in with a loose wrap. Have I got it right???
Regards...Gravelbed.
Hans Weilenmann
Post by Hans Weilenmann » Sun Nov 22, 2009 8:53 am
Indeed.
Post by letumgo » Sun Nov 22, 2009 10:54 am
It is a technique that opens up a whole new range of hackle feather, as well as hair-hackle possibilities.
Post by redietz » Mon Nov 23, 2009 12:32 am
letumgo wrote:It is a technique that opens up a whole new range of hackle feather, as well as hair-hackle possibilities.
Not to mention hook size possibilities.
gravelbed
Post by gravelbed » Mon Nov 23, 2009 9:37 am
Hi Hans......
Could I put forward a request from you!! could you please tie-up a Partridge & Orange size (18#), using the same method you used for the Bronze & Peacock, then post us the result on the forum.
Regards...... Gravelbed.
