Pearsall's Gossamer Silk Colors – Wet and Dry
FlyFisherMann1955
Re: Pearsall's Gossamer Silk Colors – Wet and Dry
Post by FlyFisherMann1955 » Wed Apr 03, 2019 5:14 pm
ForumGhillie wrote: Wed Apr 03, 2019 6:21 am
Phil should put his work in a nice wooden frame with three flymph patterns and a spool of 6B at the bottom. Or, he can just send me a spool of 6B and I will make my own. :roll:
Forum Ghillie,
I thought Sherry Spinner (#6B) only existed in the minds of people who believe in unicorns. Now, I see it's actually a real color.
Phil,
I look forward to the pictures comparing thread colors on the wooden spools versus the plastic spools. My high school colors were maroon and white. Our uniforms looked nothing like Pearsall's maroon! I think the posters could be popular. I don't have a poster of the Hardy Girl, but I could put up a poster of Pearsall's Gossamer without causing any conflict in the house!
Bazzer69
Post by Bazzer69 » Wed Apr 03, 2019 7:56 pm
Please not that colors on your screen might not be the same as mine. It’s all due to “color profiles” and unless the orginal had a calibrated system and yours has the same calibration then the colors will indeed different. Also the best photography can’t match the colors as seen by the human eye
B
But not much good at either
PhilA
Post by PhilA » Wed Apr 03, 2019 8:47 pm
FlyFisherMann1955 wrote: Wed Apr 03, 2019 5:14 pmI look forward to the pictures comparing thread colors on the wooden spools versus the plastic spools.
Ken,
Other than the old and new No.15 shown in the color chart, these are the only other Gossamers for which I have both old wooden and new plastic spools.
Left to right: Gold (formerly Light Orange), Purple, and Hot Orange.
The older spool of hot orange might be a slightly deeper shade of orange, but any difference is subtle at best.
Phil
FlyFisherMann1955
Post by FlyFisherMann1955 » Wed Apr 03, 2019 8:54 pm
Phil,
All 3 comparisons look very much the same to me. And, if i understand the timing correctly,
the thread on the wooden spools is at least 30 years old--pretty amazing!
Thanks- Ken
PhilA
Post by PhilA » Fri Apr 05, 2019 2:12 pm
Bazzer69 wrote: Tue Apr 02, 2019 8:59 pm The dramatic color change is in unwaxed thread. Once silk is well waxed it seldom changes color when in water. It’s common in Salmon flies to use a white underbody so the over wrapped colors appear more brilliant when wet. It’s always a good idea to test a new pattern under water to see if it’s the color that you expected.
B
Bazzer,
I've long thought that waxing silk thread slows but does not eliminate the darkening when wet. I'm unsure when or how I learned that supposed principle, so I did a few tests of whether well waxed silk does or does not darken when wet. The results, shown in two photos below, are in between those two extremes. Waxed thread darkens, although not quite as much as unwaxed thread.
I wrapped two layers of unwaxed Gossamer No.6B (Sherry Spinner) on a hook. I then pulled a second length of thread six times through a block of light-colored medium-hard tyers' wax (formula 7-2-1) and wrapped it on the same hook. This is the dry photo:
The silk darkened somewhat from waxing. The major effect though was removal of the silk thread's sheen. The unwaxed thread had a nicely reflective sheen (shiny surface), while the waxed thread had a "matte" finish of similar but slightly darker color.
I next tossed the hook in a tub of water. The unwaxed thread immediately darkened to its final color. The waxed thread darkened slowly to a final color that was considerably darker than when dry but a little lighter than the final color of unwaxed thread. This photo was taken after 6 or 7 minutes in the water:
The conclusions? (1) Both waxed and unwaxed silks darken when wet, but waxed thread darkens a little less (at least, with my wax and Gossamer No.6B). (2) Gossamer No.6B is beautiful when wet!
I should say that, of all the things that make for successful trout fishing, color is way down on the list of things that I think are important. Presentation and size, for example, are much more important in my opinion. If, however, a tyer desires a specific final color, flies tied with silk need to be checked when wet.
Phil
PhilA
Post by PhilA » Fri Apr 05, 2019 2:18 pm
daringduffer wrote: Wed Apr 03, 2019 1:23 pm Next step should be to keep both hook/thread and camera subsurface. That might give a different outcome.
dd,
Have you met the Forum Ghillie? He is a mischievous fellow also, and you would get along quite well together.
Your pal,
Phil
P.S. Your spool of No.4 (Light Yellow) was mailed homeward earlier this week, along with a medium dun hen cape. The post office estimated 1-2 weeks for delivery.
Post by Old Hat » Fri Apr 05, 2019 3:45 pm
Bravo Phil!
Post by daringduffer » Fri Apr 05, 2019 4:07 pm
PhilA wrote: Fri Apr 05, 2019 2:18 pm
dd,
Your pal,
Phil
Phil, John is my American twin brother ;) . No, I am a lot more shy and polite and respectful and all that but I would like to meet you both. I'm somewhat busy this week but maybe next? I look forward to the medium dun silk.
I regard your work as important even if colour might not be of great importance to the fish. Even if Pearsall's is vanishing, silk will probably always be used. Now tiers aware of your charts will start to think, not only of colour of wet silk but all materials used. We will think, not only of colour but of other qualities as well; reflectance and what not. So, good work.
Regarding the difference of colour of silk on plastic and wooden spools; I think some of it comes from the different contrast of white plastic and woody wood. Now if you just shift the silk between spools and photograph them and........
PhilA
Post by PhilA » Fri Apr 05, 2019 4:31 pm
daringduffer wrote: Fri Apr 05, 2019 4:07 pm I look forward to the medium dun silk.
Stefan,
Don't get your hopes up. The medium dun is a hen cape. But, nice try ...
I would enjoy sharing a campfire and consumable alcoholic beverages with you as well. That is, until I found my sleeping bag full of prickly thistles.
Phil
Bazzer69
Post by Bazzer69 » Fri Apr 05, 2019 5:26 pm
Phil, thanks for the comparison between waxed and unwaxed silk. I’m not sure if I’m totally correct but didn’t all the past masters always wax their silk? I’m also wondering if waxed silk is stronger than unwaxed. I can certainly imagine it frays less from a fishes teeth. When I want to keep a color bright I’ll wrap a underbody of white silk or United-stretch. Much of the darkening is due to the silk getting a little transparent when wet and the hook colour showing through.
Barry
