by Ruard » Fri Jun 14, 2013 6:33 am
In Grantsville Doug gave me (tnxs Doug) a whole box of goodies and with it came a nice piece of wood to make a dubbingblock from it! I use mine mostly to make dubbingbrushes with copperwire thread in it, but I thought could it be possible to to make a double use of it: a normal clark block and a reversed one.
here are the pictures of it:
Right is the threadsection and left the copperwire section
And now I turned it 180degrees and start with the copperwire
Final result:
by tie2fish » Fri Jun 14, 2013 7:42 am
Aren't you the clever one? That's very cool, Ruard.
by Ruard » Fri Jun 14, 2013 7:44 am
tie2fish wrote:Aren't you the clever one? That's very cool, Ruard.
Thank you Bill
greeting
by letumgo » Fri Jun 14, 2013 8:26 am
Ruard - Excellent design! Do you mind if I copy your design ideas? I would like to take the block & pins Doug sent and do something similar with mine.
I have some additional photos showing you using your previous dubbng twister block. Would you mind if I post them here, to show you in action?
by Ruard » Fri Jun 14, 2013 11:09 am
letumgo wrote:Ruard - Excellent design! Do you mind if I copy your design ideas? I would like to take the block & pins Doug sent and do something similar with mine.
You are welcome sir.
by Kelly L. » Fri Jun 14, 2013 11:24 am
Dubbing blocks are so cool. I am thrilled with mine. I like your design!
by letumgo » Fri Jun 14, 2013 12:19 pm
by Kelly L. » Fri Jun 14, 2013 1:19 pm
Awesome photos. I have a large block, that I use for larger dubbing brushes...you can even use synthetics with it. I use small copper wire to twist it up. We use that for baitfish patterns. I haven't used it in ages though. I have been too busy tying these little flies.
by Mataura mayfly » Tue Jun 18, 2013 7:53 pm
Excellent idea Ruard, I like the way you think.
