Distressed Damsel
Izaak
Distressed Damsel
Post by Izaak » Wed May 02, 2012 6:12 pm
DSCN4319 by flympher, on Flickr
DSCN4320 by flympher, on Flickr
Hook: TMC 206BL, size 14
Thread: Danville 8/0, olive
Hackle: Partridge, dyed olive
Body: Fur cut from rabbit strips, dark olive, encircling hook shank
Re: Distressed Damsel
Post by hankaye » Wed May 02, 2012 9:12 pm
Izaak, Howdy;
Onlyist way i can think of to DE-stress that fly
would be to take it fishin' ..... ;)
Post by letumgo » Wed May 02, 2012 10:38 pm
Brilliant!
Post by Kelly L. » Thu May 03, 2012 1:37 pm
I like the look of it when it's wet, very nice!
Donald Nicolson
Post by Donald Nicolson » Thu May 03, 2012 2:07 pm
A nice looking fly.
Izaak
Post by Izaak » Thu May 03, 2012 2:44 pm
You don't think it looks too much like a soft hackle fly with some trailing moss/algae on the hook? :? :D
Post by Mataura mayfly » Thu May 03, 2012 3:05 pm
Izaak wrote:You don't think it looks too much like a soft hackle fly with some trailing moss/algae on the hook? :? :D
I do not think so, as you are not as "green" with your body material as the slime you pick up sometimes on the hook of a slow deep fished wet. In saying that I have taken trout on a "slime trailing" fly before!
Do you thing the barbs of your hackle are soft enough that they will arch on the retrieve to form a thorax and "pop" back to the position in your wet photo on the stop? If so I think it would be a very exciting pattern to fish.
Izaak
Post by Izaak » Thu May 03, 2012 3:21 pm
mm,
Yes, I think the barbs will compress back a little bit when the fly is stripped, and on the pause will probably flare back out. Likewise with the rabbit fur. It should look very similar to the top photo when submerged and thoroughly saturated, and not moving. When stripped through the water the fur should look similar to the bottom photo. I think! ;)
Post by Soft-hackle » Fri May 04, 2012 10:12 pm
Wonderful tying, Tom, and a sweet idea. Just add water--OH-you did! That makes it.
