Quick and Dirty Fishing Patterns
Post by letumgo » Fri Jun 29, 2012 1:44 pm
I am going fishing with our friend Tim Didas (tjd) this evening and wanted to whip together some patterns to test out. I was rushing to get these tyed and photographed. Anyway, I though I would share these before they get fished. Wish me luck!
Olive Seal-Blend Soft Hackle
Hook - Mustad Model R50/Size 12
Thread - 8/0 UNI-Thread (Wine)
Hackle - Indian Hen Saddle Feather (Speckled Brown)
Tag/Under Body - UTC Mylar Tinsel/Small (Silver side showing)
Abdomen - Fly Tying Dungeon's Legs Alive (Olive)
Thorax - Olive dubbing blend (Natural/Light Olive/Medium Olive Seal & Aussie Opposum) - Blend was created by William Anderson. Beautiful stuff. Thanks William.
Brown & Peacock Pupa Soft Hackle
Abdomen - Fly Tying Dungeon's Legs Alive (Brown)
Thorax - Three strands of Peacock Herl (Natural) - Reinforced in a thread dubbing loop
CAUTION - BEAD HEAD CONTENT
IF YOU ARE AT ALL SQUEAMISH
AVERT YOUR EYES NOW
Tungsten Bead Head Peacock Herl Leech
Hook - Tiemco (TMC) Model 700/Size 6
Bead Head - 1/8" Tungsten Bead (Gold)
Tail/Body - Ten to Twelve Strands of Peacock Herl (Natural) - Tyed long to form the tail. Tyed "full" to form the body. The taper is formed by tying in another section of herl at the front half to bulk up the front section. The body is all reinforced with a thread dubbing loop.
We may be night fishing for browns, so I wanted something big and dark which I can swing thru the depth. I am looking forward to fishing this fly!
gig
Re: Quick and Dirty Fishing Patterns
Post by gig » Fri Jun 29, 2012 2:38 pm
Love the Brown & Peacock Pupa Soft Hackle. How did you go?
Life is good, why waste it.
Post by William Anderson » Fri Jun 29, 2012 3:31 pm
These look great. I'd be excited about these too. Especially that depth charger. Should be a killer. I hope you guys have a great evening. Get some pics.
Post by Old Hat » Fri Jun 29, 2012 7:02 pm
That brown and peacock would catch fish anywhere anytime.
Post by redietz » Fri Jun 29, 2012 8:29 pm
I'm thinking that the leech, tied a bit smaller, would make an excellent iso nymph pattern.
Post by hankaye » Fri Jun 29, 2012 10:03 pm
Ya, let's see what they look like after an evenings swim... :D
Good looking flies each an every one...
Post by DUBBN » Sat Jun 30, 2012 6:44 am
If you didnt do well fishing last evening, it wont be the fly's fault. Each pattern you posted looks great.
Post by tie2fish » Sat Jun 30, 2012 7:05 am
Even in a rush, your creations are super fishy looking, Ray. I'll side with those others who rave about the brown & peacock, but all three look like they'll catch.
gingerdun
Post by gingerdun » Sat Jun 30, 2012 12:23 pm
I hope the trout wreak havoc and chew those beauties to the wire.
Last fall I was goofing off with some ostrich herl, and tied a couple very similar to your peacock leech, but was too embarrassed to show them to anybody. Now I'm thinking I might dunk one in the water next week just to see what happens.
Lance
Post by letumgo » Sat Jun 30, 2012 12:38 pm
None of these flies got fished last evening. Once I got to the place we were fishing (spring creek conditions/lots of weeds/shallow crystal-clear water), and saw the type of flies that Tim was using (tiny flies/some of his flies were tyed down to size 32's), I quickly change plans. My flies looked gargantuan for the water we would be fishing. The bead heads were simply a recipe for disaster in the weeds of these streams.
Here is a view from the bridge looking into good holding water. As I watched the stream for a while, I saw multiple rises and one huge brown chasing a minnow out of the water along the far side.
Spring Creek - Cold water (58°F) and crystal clear conditions - Lots of weeds swaying in the current.
View under the railroad tracks:
Here is a view, looking down stream while standing on the railroad tracks. If you look very carefully, you can see Tim sneeking into position along the trees at the edge of the stream. He is standing near the bottom of the embuttment.
Here is my first fish of the afternoon, and the biggest one I caught from the spring creek. Nice brown, which had to be dragged out of the weeds. I was using 7X tippet, so I worried he was going to break off.
"I said I don't want my photo taken!" ---Flip...Splash...and he was gone... A nice healty and very feisty fish!
Brook Trout
I caught a total of eight trout, and missed many others.
So what did I catch them on? One of Bill Shuck's soft hackle nymphs (callibaetis imitation I believe). Thanks Bill. Once again, your flies were the answer! (I just noticed that these are barbless).
The stream was lined on both sides with trees/vegetation, making any sort of back cast next to impossible. Fortunately I had brought along my fiberglass rod, which does a nice job with a simple roll cast. I was able to stand on the edge of the stream and flip a roll cast nearly to the other side. I tried drifting the fly down thru the runs/weed lines but could not get the fish interested. At one point I was lifting the tip of my rod, preparing to make another roll cast, when I got my first strike. The fly had been rising towards the surface, as the line was pulled off the water. That first fish showed me that they would respond aggressively to a fly in motion. From that point onward, I was roll casting to various spots, waiting a few seconds for the fly to sink, and then lifting the rod tip in a slow steady movement to cause the fly to rise to the surface. I was able to work back and forth over this small section, without moving or disturbing the weed beds in front of me.
When it started getting dark, Tim and I headed to another location. We were going to be fishing for big browns in full darkness, so we switched tactics and gear (heavy line and BIG flies). Here is a shot of Tim's fly box. Man can he tye! Superb collection of fishing streamers.
As the sun went down, and dark settled in, the fireflies came out and put on a light show. It was magical standing in the stream and hearing big fish splashing, as they hunted along the weeds. I managed to hook and land one fish (10"), but I missed three others. One of them had some "shoulders" to it (meaning that it was a BIG fish). I played him right up to my feet, but he flipped off my line, as he got into the weeds. I wish I could have netted that one...
At one point, Tim reached down and grabbed a small handful of the green vegetation in the stream and showed it to me. As he jostled the weeds around, his hand was filled with an array of wriggling scuds/fresh water shrimp. The weeds were loaded with these things. No wonder the trout love these types of streams. Lots of food. Nice cool water, and lots of cover to hide in. Trout heaven...
We fished until midnight and then headed home.
Thanks Tim, for teaching me how to fish a spring creek! What a fantastic way to spend a summer evening.
