1.) Standard issue flymph:
2.) This is a variation of a local pattern popularized by Hugh Hartsell--it uses a split primary or tail feather as the hackle (though Hugh uses a body of black rabbit dubbing, I believe.)
3.) And a version of the classic "Yaller Hammer;" as the name implies, it was originally tied with a split primary feather from a northern flicker. Modern (not to mention legal
At any rate, one thing these flies taught me is that I need a whole lot more practice splitting feather stems...I'm not sure if it's quite worth the effort to go through the whole soaking/razoring procedure, but it does let me use feathers off of a pelt that would normally go to waste.
