Red A$$ Red Tag (Brown Hackle Peacock)
Post by DUBBN » Mon Aug 19, 2013 4:49 pm
Hook- Mustad 3399, size 12
Thread - UTC70, Black
Collar - Brown hen
Tail - Glass beads, Red
Body- Peacock
Re: Red A$$ Red Tag (Brown Hackle Peacock)
Post by Mataura mayfly » Mon Aug 19, 2013 5:42 pm
Risqué and out of left field......... I like it! :D
So is the fly trying to pass a bloodworm after an ambitious meal? Or is the bloodworm feasting on the fly? :P
All joking aside, I like the idea and method behind it. The beads certainly make a statement, not subtle, but not overpowering either.
My only concern would be bead collision leading to subsequent destruction whilst casting?
Post by William Anderson » Mon Aug 19, 2013 7:44 pm
Hate to be crude, but can't let it go either. This makes Ray's hemorrhoidal hot spot fly look like a good day. I suspect it will get plenty of attention. Is this a mono loop around the last bead?
Post by hankaye » Mon Aug 19, 2013 7:46 pm
DUBBN, Howdy;
Must still have some chokeberries on the mind, or the after effects of to many ingested... :roll:
Nifty lookin' beast. How'd you attach the beads ??? Some of that red Mono you use to attach tags
to swap flies and melt the end?????
tjd
Post by tjd » Mon Aug 19, 2013 7:48 pm
DUBBN,
I used to tie a steelhead fly I called the "Hemorrhoid Smurf"...a little blue pattern tied with a lacquered butt of flourescent fire orange Danville's Flymaster. Not even in the same league as yours!
Lots of potential...well done!
Best,
Tim
Post by DUBBN » Mon Aug 19, 2013 7:57 pm
Yes, it is a 12 lb. test, mono loop. I think it will look a tad neater if I use 6x or 7x tippet for the loop. I plan on tieing some baetis nymph/emergers with the technique, so I will have to drop down in mono size. Bead size as well.
JohnP
Post by JohnP » Mon Aug 19, 2013 8:06 pm
Nice fly, Wayne. You are always thinking outside of the box.
By the way, your muskrat pattern was a hit with Yellowstone cutthroats in a certain beaver pond. :)
Post by William Anderson » Mon Aug 19, 2013 8:07 pm
Wayne, your attachment technique is great of course, but you could also stay with the larger mono, using a single length and flaring the end with a lighter, slip on the beads to the mono andthen tie in to the hook shank. That would allow all beads to line up, not that it matters, just a thought. I'm looking forward to seeing the variations. Very forward to the stream pics.
Post by letumgo » Mon Aug 19, 2013 10:12 pm
Perfecto! Love it! Immaculate dressing Wayne. Beautifully photographed.
Post by tie2fish » Tue Aug 20, 2013 7:55 am
Creative, innovative ....... genius. Kudos, clever sir!
