Cruella de Ville Soft Hackle
Post by letumgo » Wed May 11, 2011 7:04 pm
Hook - Mustad Model R50-94840/Size 10
Underbody - Woolly Nylon (White)
Abdomen - Micro Tubing (Red)
Thread - 70 Denier UNI-Nylon (Black)
Thorax - Two Strands of Ostrich Herl (Black) - reinforced in a thread dubbing loop
Hackle - Hungarian Partridge (Natural with prominent brown markings towards tip)
* materials are listed in the order they are attached to the hook
My wife came up with the name of this fly. She said the color combination reminded her of the Disney character.
Re: Cruella de Ville Soft Hackle
Post by CreationBear » Wed May 11, 2011 7:52 pm
Now that, sir, is a brookie fly. :) That's a wonderful taper to the abdomen as well--I'll have to hunt up that particular thread as well. :)
Post by letumgo » Wed May 11, 2011 8:07 pm
CB - You can find the woolly nylon material in the sewing section of any Joann Fabric store. The stuff comes on spools of 1000 meters for around 5 dollars. I bought a spool of the white to use as underbodies. It makes incredibly smooth bodies. Woolly nylon is very similar to UNI-Stretch, with a slightly larger diameter. I started using woolly nylon a few years ago, after watching some of the full dress salmon tyers using it to create large tapered bodies. Great stuff!
kanutripr
Post by kanutripr » Wed May 11, 2011 8:24 pm
That's great Ray! Very attractive. Love the name as well!
Vicki
Post by CreationBear » Wed May 11, 2011 8:54 pm
Excellent, thanks for elaborating on the materials: any significance to your using Uni-nylon for this pattern?
Also, if I could ask a favor: any chance of you posting a photo of the woolly nylon you're talking about? I pester the poor gals working there enough looking for various and sundry silk materials. :)
Post by Roadkill » Wed May 11, 2011 9:14 pm
A very nice tie and great photo! :D
Post by letumgo » Wed May 11, 2011 9:48 pm
CB - The main reason I used UNI-Nylon on this fly is it's size (small diameter). The woolly nylon can add bulk in the head area, so I chose a fine diameter thread to compensate. I find that I can tye smaller heads with this thread and it has the advantage of going completely flat when it has no twist. It is easily split with a needle, making it ideal for inserting a little dubbing to form the body on flies. The only disadvantage I can find is that it can fray or break if you apply too much pressure. Like all things, it just takes a little getting used to.
I will post a picture of the woolly nylon material shortly.
Post by letumgo » Wed May 11, 2011 10:14 pm
CB - Here is a photo of the woolly nylon material (the large spool). I filled an empty thread spool with this material so that I can tye with a standard bobbin. I simply mounted a wooden dowel in my cordless drill, slid the empty thread spool over the dowel. Attach the end of the woolly nylon to the empty spool and start the drill and wind on the desired amount. As you can see, one spool of woolly nylon is probably a lifetime supply...
Post by Old Hat » Wed May 11, 2011 10:59 pm
Great stuff. Fly and discussion. Now I just need to find a Joann's. Yes, I am isolated.
Post by willowhead » Wed May 11, 2011 11:15 pm
Great fly.........thankx for the tip Ray. ;)
