Palomino's
Palomino's
Post by Ruard » Mon Mar 16, 2009 4:22 am
Palomino's.
I have tied three different Palomino's. I will give them a try next weekend: we go to Baggelhuizen, a trout pond in the Netherlands.
Hook: Kamasan 110 no #12
tail: black suede chenille burnt on the end
Thorax: red seal or sub
hackle: Metz hen saddle ginger brown
Thread: Claret
tail: pink suede chenille burnt on the end
Thorax: purple seal or sub
Thread: Claret
Thorax: olive rabbit fur
Thread: Claret
skunkaroo
Re: Palomino's
Post by skunkaroo » Mon Mar 16, 2009 11:52 am
Ruard,
I've used this extended body style for dry flies with some success, but I hadn't thought of it for soft hackles. I'll be interested in hearing the results.
Author Stream Time Blog
Re: Palomino's
Post by Ruard » Mon Mar 16, 2009 12:19 pm
I shall try them next weekend. The extended body-style I use is much easyer then what I see in the picture of your fly. How did you make your body?
skunkaroo
Re: Palomino's
Post by skunkaroo » Mon Mar 16, 2009 1:30 pm
Simple, if a little time consuming...
  1. Wick the chenille with a lighter to get the right taper
  2. Set a needle in your vice (pointed end out)
  3. Take your tail material (in this case paint brush bristles), place them along the "top" of the chenille and tye-in parallel to the needle
  4. Bring the thread rearward and then back to the tye-in point and cast off
  5. Brush the top surface with superglue, let set for a moment, and then slide the whole thing off the needle
  6. Complete fly with the extended body
The only trick is to keep the thread from twisting the chenille as you wrap-use soft loops rather than wrapping it as such.
I can't remember where I saw this method detailed, but the effect is quite unique.
Re: Palomino's
Post by Ruard » Mon Mar 16, 2009 2:12 pm
skunkaroo wrote:Simple, if a little time consuming...
  1. Wick the with a lighter to get the right taper
Thank you Aaron. I presume that you mean: Wick the chenille with a lighter.
Thank you for posting. For the Palomino as an imitation of a Mosquito I rather use the plain chenille a little burnt on the end. :)
skunkaroo
Re: Palomino's
Post by skunkaroo » Mon Mar 16, 2009 2:18 pm
You are correct... I guess spell check wouldn't have caught that one :).
Re: Palomino's
Post by William Anderson » Mon Mar 16, 2009 4:10 pm
Ah yeah, Ruard, I forgot about those. and as a soft-hackle they make perfect sense. I tied some a bit ago as caddis emergers, and these are really nice bugs. thanks for sharing those.
RnF
Re: Palomino's
Post by RnF » Mon Mar 16, 2009 6:05 pm
Very nice ties Ruard! Rainy's makes some nice extended bodies of various sizes and colors, worth checking out.
I like these a lot, I am going to have to tie some of these up, I can think of many applications to use this type of fly.
Scott D
Re: Palomino's
Post by Soft-hackle » Mon Mar 16, 2009 8:20 pm
A super looking idea. They've got to be great fish catchers.
WebbyFeathers
Re: Palomino's
Post by WebbyFeathers » Wed Mar 18, 2009 5:20 pm
Great idea for SHs.
