paparex,paparex wrote:A question for Hans but would like to hear from all who wish to weigh in on the question. Here it is: How many changes to a pattern make the fly a variant? Follow up question: How many changes result in a new fly?
An often debated question and I have yet to see it reach a broad based consensus
Here are some of my thoughts.
If it is one's own pattern, then it is simple. I can name my patterns any way I choose, even when a pattern may undergo a number of revisions changing in subtle or less subtle ways the pattern's look&feel.
I will try to steer clear of duplicating the name of an established pattern, of course, in an attempt to avoid muddying the water - but with millions of tiers whipping up, and naming, many millions of flies, unintentional overlap is hard to avoid.
Things change when tying up another tier's established, published, or otherwise 'known' pattern. There I become much more careful.
Let me stop for a moment, and consider that the pattern I have become aware of, and which I am interested in tying up some for my own use, may have come to my attention in a number of ways. If I have a clear reference - an actual sample to look at in detail, or a good quality image, of an 'original' or a direct conversation with the originator - then I will have a decent understanding what makes a pattern 'tick', and what the tier has intended. If I then tie up a copy, and I remain true to the 'look&feel' of the original, then I will quite happily call it by its original name. Please note the 'look&feel' - I may tie up the pattern with a change in techniques, or I may substitute some of the materials, as long as 'look&feel' remains intact, and if I believe the pattern will behave and fish 'identical' - then the original name is what I will use. A case in point - I tie the Frank Sawyer Pheasant Tail nymph using different techniques from how Frank has documented it, but my result fly is 'look&feel' identical - and I will refer to it, or publish it, as a Sawyer Pheasant Tail nymph.
If I only have second or third hand familiarity with a published or known pattern, such as access to samples or images of the pattern tied by someone other than the originator I will become much more cautious. I will not be able to have a good sense of whether I have captured the 'look&feel' of the original, and will either name it different, or will add Variant or Variation to the name and where able will add a reference note to the originator of the pattern.
I would be interested in how others view the matter, and hope they will share their thoughts.
