Flashabou experiments
gingerdun
Post by gingerdun » Thu Nov 15, 2012 11:05 pm
This is my first time using Flashabou or any of that kind of material.
I've been curious about it, and impressed by how it seems to condense and intensify light reflections.
This Flashabou is the one called Lateral Scale that is crimped into a zig-zag, breaking up the reflections when laid straight. But when wrapped around the hook, the crimping doesn't show. I guess it is intended to be used in a straight line, on each side of the fly, or streaming.
There have been a lot of flies posted here with flashabou, so this is just an addition to that group.
Hook—14 Jim Bashline Wet Fly (Gaelic Supreme)
Silk—ash
Hackle—Dark grizzly hen
Rib—lateral scale flashabou
Tail—lemon woodduck
Body & thorax—muskrat tips on ash,
Hook—12 Jim Bashline Trout Wet Fly, Gaelic Supreme
Silk—ash
Hackle—rusty dun hen
Tail—lemon wood duck
Rib—Flashabou, lateral scale
Body—pale brown Argentinian hare on ash
Hook—12 Jack Mickievicz Letort Dry Fly
Silk—gold
Hackle—speckled hen dyed yellow
Body—golden olive embroidery wool, single strand
Thorax—bronze peacock herl, two strands
When I bought this Flashabou from Mike Hogue, Badger Creek Fly Tiers, he asked whether my father ever would have used it. I honestly don't know the answer. I suspect that he would have tried it, but we'll never know.
Lance
Re: Flashabou experiments
Post by Mataura mayfly » Thu Nov 15, 2012 11:45 pm
Very nice Lance. Classic in shape, with a modern flash.
Have you tried using it on the dubbing block yet as your base thread? Can lead to some interesting results and twisting it into a dubbing rope can yield yet another effect of how it reacts to the light.
All three are worthy of a place in most fly boxes, would be interesting to fish the same patterns, one with flash and one without to see which the fish prefer. Like the cocked tail of the second, but the colours and fast tapered body of the third are pretty special. :D
Post by Old Hat » Fri Nov 16, 2012 12:47 am
Lance, all three of those are quite beautiful flies. I have a fond spot for pearl flashabou as ribbing or a base layer. I don't use it a lot but but have a few patterns. It provides quite a lot of different effects depending on the dubbing it is applied over.
Post by Ron Eagle Elk » Fri Nov 16, 2012 2:27 am
Lance, Beautifully dressed flies. Just out of curiosity, are you stretching the flashabou when you wrap it, or is it wrapped somewhat loosely?
gingerdun
Post by gingerdun » Fri Nov 16, 2012 7:07 am
Thanks for the feedback.
Jeff, never occurred to me to use it on the dubbing block. Will give it a try. Testing the patterns with and without flash is a good idea. I'm curious.
Carl, I see what you mean about the variable effects in combination with other body materials. That's why I tried the golden olive embroidery wool as an undercolor on the third fly. I'll have to try using flash as the under layer too. I saw that you were using the Jack Mickievicz Gaelic Supreme hook in your Grizzly Hare post. The Jack Mickievicz dry fly hook is very light as you pointed out, and one of them broke when I lightly tested it in the vise. But the next one seemed tough enough. I used the more sturdy Gaelic Supreme Jim Bashline wet fly hooks for the first two flies. That green finish is unique.
Ron, it did not occur to me to try stretching the flash. I just wrapped it lightly but firmly, as though it were wire. I can see the advantage of stretching it first to make it thinner, especially for smaller flies. Is that what you do?
Lance
Post by CreationBear » Fri Nov 16, 2012 8:14 am
Like these a lot, especially Fly #2--just perfect proportions and color combination. :) (BTW, I've liked all of the Gaelic Supreme hooks I've tried--the "Yorkshire Caddis" makes an interesting alternative to, say, the TMC206.
Post by William Anderson » Fri Nov 16, 2012 9:03 am
Lance, you've really put up a lot to discuss in these flies. I'm first struck by the beautiful compositions of each and the body tapers on these hooks. Really well done. The hooks are fantastic. I haven't had the privelege of tying on either but they make beautiful frames for these and Carl's flies. I appreciate the way you've used a material that could easily have come off on the garish end of things, but these flies still retain a more modest, natural look about them. Great flies. Based on what you've shown of your father's fly wallet, I would think this material would have caught his eye as well. He wasn't shy about experimenting with materials. Great post.
Using this or a similar material on the dubbing block is similar to the fly Bill - tie2fish, just posted and it turned out fantastic. It's a great idea and definitely something to follow up. The flashabou will make for a more dazzing spun body, but it's a cool idea.
http://www.flymphforum.com/viewtopic.php?f=6&t=3827
fflutterffly
Post by fflutterffly » Fri Nov 16, 2012 9:35 am
Very nice experiment. I've also twisted the Flam to make a tight 'rope' and used it as ribbing, flat used as ribbing as you did, and over the wing casing as many have done. It's a very useful material. I think each of these flies would do well sub surface just after a plunge into a nice deep hole. Yummmmmm!
Post by letumgo » Sat Nov 17, 2012 9:11 am
Jimeny Cricket! Those are some FINE looking flies. I love the ribbing material.
Post by Old Hat » Sat Nov 17, 2012 11:03 am
Thanks for the heads up on the hook Lance. I'll keep an eye out. I just received a package and started to use it. I have used the Bashline hooks for a couple years. I like the style and the hook, the green finish bugs me a bit but as far as fishing with....a great hook. I have also been using the Syl Nemes hook and like it a lot.
