Dark Watchet
Roy
Dark Watchet
Post by Roy » Tue Feb 24, 2009 4:32 pm
Dark Watchet # 16
orange and purple Pearsall's silk
water rat fur
jackdaw throat hackle
skunkaroo
Re: Dark Watchet
Post by skunkaroo » Tue Feb 24, 2009 4:37 pm
Intense, Roy! That's got Electric Kool-aid Acid Test written all over it. I can almost here Jimi in the background. :D
Nice fly.
Re: Dark Watchet
Post by William Anderson » Tue Feb 24, 2009 5:25 pm
Roy, even my internal automatic internet color adjustment feature is having a tough time translating the colors of that pic. But understanding the materials used and knowing your preferences, I can still see it as waxed orange and purple, although it does look like you used a special "Purple Haze" filter to get that effect. I especially like the "Little Wing" approach. :D
xcuze me, while I kiss the sky!
Roy
Re: Dark Watchet
Post by Roy » Tue Feb 24, 2009 5:33 pm
nutters,
When this thing first saw wax greensleeves was at the top of the papyrus chart for the lute.
:shock:
:mrgreen:
Re: Dark Watchet
Post by Ron Eagle Elk » Tue Feb 24, 2009 6:11 pm
I like it a lot. I thought my computers col;ors were a bit off untill you mentioned wax. Very nice.
REE
Re: Dark Watchet
Post by redietz » Tue Feb 24, 2009 6:37 pm
skunkaroo wrote:Intense, Roy! That's got Electric Kool-aid Acid Test written all over it. I can almost here Jimi in the background. :D
As a card-carrying Deadhead, it's my duty to inform you that the house band at the Electic Kool-aid Acid Test was most certainly not the Experience.
Roy -
How do you handle the two threads? Twist them together and wrap both ways? Or just wrap on back with the other underneath, twist both together at the back, or just use one as a rib? If the latter, which are you adding dubbing to, the base thread or the rib?
skunkaroo
Re: Dark Watchet
Post by skunkaroo » Tue Feb 24, 2009 7:42 pm
redietz wrote:As a card-carrying Deadhead, it's my duty to inform you that the house band at the Electic Kool-aid Acid Test was most certainly not the Experience.
You old stoner :lol:
RnF
Re: Dark Watchet
Post by RnF » Tue Feb 24, 2009 8:34 pm
Nice contrast. That should be deadly.
Scott D
Liam
Re: Dark Watchet
Post by Liam » Tue Feb 24, 2009 9:27 pm
Not to be a snot- but why use water rat? Edmonds and Lee call for mole. Do you like the water rat better? The tie is terrific, by the way.
Re: Dark Watchet
Post by redietz » Wed Feb 25, 2009 1:30 am
Liam wrote:Not to be a snot- but why use water rat? Edmonds and Lee call for mole. Do you like the water rat better? The tie is terrific, by the way.
But here's what Pritt has to say:
No. 1 8. LITTLE DARK WATCHET (Iron Blue Dun),
Hook O short.
WINGS. Hackled with a feather from a Jackdaw's neck, or
outside a Coot's wing.
BODY. Orange and purple silk twisted, dubbed with down
from a water-rat.
HEAD. Orange.
He actually listed four patterns with the same name; two of the others were winged, and the fourth is water hen & orange, with mole dubbing.
I guess either one is historically justifiable.
