fishhead
by fishhead » Thu Mar 24, 2011 10:49 pm
hook mustad size 12
thread UNI olive 8/0
tail and body pheasant tail
rib gold mylar tinsel
thorax peacock herl
hackle olive hen
by William Anderson » Thu Mar 24, 2011 10:58 pm
Nice solid nymph to emerger pattern. I like the thinner nymph type bodies and this is a really nicely put together pattern. Did you tie in by the tip and finish behind the head? I keep meaning to try that as it was described by Jim earlier. I need to put down the wire and start tying some herl bodies.
fishhead
by fishhead » Thu Mar 24, 2011 11:17 pm
Thanks for the comment, I tied the hackle in from the base not the tip and finished in the front. I have tried different methods of tying in the hackle without great results. Probably just not doing it correctly.
by William Anderson » Thu Mar 24, 2011 11:22 pm
No, you put it together beautifully. I just saw the strand of thread behind the hackle and thought you had pulled off something I had been meaning to try myself. It looks great. Did you dye the hen or find an olive hen cape somewhere?
fishhead
by fishhead » Fri Mar 25, 2011 12:10 am
I bought the cape already dyed olive
lykos33
by lykos33 » Fri Mar 25, 2011 9:11 am
I like the thin sparse bodies and the sparse hackling also, great job on this one fishhead!
fishhead
by fishhead » Fri Mar 25, 2011 6:46 pm
William Anderson wrote:No, you put it together beautifully. I just saw the strand of thread behind the hackle and thought you had pulled off something I had been meaning to try myself. It looks great. Did you dye the hen or find an olive hen cape somewhere?
that is actually a piece of the feather, must just be how the pic came out because it does look like thread there.
by willowhead » Mon Mar 28, 2011 2:12 am
i like it very much........i might have made the thorax area bout twice that size/length.......but that's neither here nor there.........you did a beautiful job
